60 foot times versus ET 1/4 mile
Hello dragracing fans
Thinking of next season and my coming runs to break my personnel record :) Going to put a new set of backtires to get a proper grip and then it should be easy ;) Below I calculated this http://www.wallaceracing.com/calc60ft.php Enter Vehicle ET (1/4 mile): 11.92 125 mph Estimated 60 Foot Time: 1.65688 seconds. And last summer I drove like this, my 60 feet time was 2.050...awful:hide: http://www.youtube.com/watch?v=xZu0Z...d_QCyoJ1EQup8a What do you think my new record will be....:) |
Numbers don't seem to be accurate in my case. My 60 is higher than what it states
Originally Posted by Former67er
(Post 1580115285)
Thinking of next season and my coming runs to break my personnel record :) Going to put a new set of backtires to get a proper grip and then it should be easy ;) Below I calculated this http://www.wallaceracing.com/calc60ft.php Enter Vehicle ET (1/4 mile): 11.92 125 mph Estimated 60 Foot Time: 1.65688 seconds. And last summer I drove like this, my 60 feet time was 2.050...awful:hide: http://www.youtube.com/watch?v=xZu0Z...d_QCyoJ1EQup8a What do you think my new record will be....:) 11.92-1.5(2.05-1.75)=11.47 |
Originally Posted by tabbruzz
(Post 1580116347)
Originally Posted by GARY2004Z06
(Post 1580118078)
This is very generalized. For every tenth in 60' you cut, you cut about 1.5 tenths off your ET. So a 1.75 60' under the same conditions may yield you an 11.47.
11.92-1.5(2.05-1.75)=11.47 So I have to do a lot more than backtires to have a high 10 second run :D Time will tell :) ;) |
(Post 1580118180)
Thank you...this is maybe a speculation but gives me a hint what is coming
I have a TKO-600 with 2.87 1st and 3.55 in the rear :)
I have the torque, its something 600ish, the part that needs adjustment is between the seat and the steering wheel :D |
I'm trapping 11.20's at 119-120 mph with a 1.52 sixty foot time...3:90 gears in a turbo 400...
10.19 et at 132.10mph on a 1.365 sixty 3.73 gears with a amr built 4l60e trans wallace has me at a 1.41 sixty a bit off id say
(Post 1580123667)
I have the torque, its something 600ish, the part that needs adjustment is between the seat and the steering wheel :D We all can use that adjustment. :rofl: |
