Photo: What Terminal Crimper will work?
http://img684.imageshack.us/img684/4305/sam0407n.jpg
What model terminal crimper will crimp these double wire crimps? Delphi PDF Catalog: delphi.com/pdf/contact/brochures/DCS_GlobalCatalog.pdf Their crimper tools are on pages 378-379. Model No: 12040070 is the only one that mentions “doubles”, but sells for $90 and has limited usefulness, since I won't be crimping many doubles. I'd prefer one to do both doubles and singles. I’ll be using it for wires 0.35 - 3.0 mm^2 (possibly larger on future jobs). Has anybody used the "S & G Tool Aid 18920 Ratcheting Terminal Crimping Kit- 5 Piece"??? Would that work on both? I’d prefer one tool, possibly with interchangeable dies, to handle as many jobs as possible. I prefer to use a crimper. I don't want this to turn into another crimp vs. solder debate. Thanks! |
I've used kits similar to the S&G, they work great on just about any size wire or terminal.
However, 99% of what I crimp is done with one of these. I haven't had any problems yet. Even with double wires, if you twist them together first you shouldn't have any issues with the crimp. |
Originally Posted by markcz
(Post 1580094709)
(Post 1580094709)
However, 99% of what I crimp is done with one of these. I haven't had any problems yet. Even with double wires, if you twist them together first you shouldn't have any issues with the crimp. The insulation crimp is important as it places the fulcrum on the insulation, instead of the more brittle core. I've seen plenty of problems (often intermittent) caused by bad insulation crimps, although they had great core crimps. The copper strands tend to bend and break at that point. |
If the wire is breaking under the insulation crimp it was probably crimped too tight. Squeeze until you see stars on the wire, but just enough to get it snug on the insulation.
(Post 1580094917)
If it's breaking the wire between the two crimps that would make me think the insulation crimp wasn't tight enough :ack:
If you're replacing the wires make sure you add enough slack so it doesn't get stressed this time :D |
(Post 1580095232)
If you're replacing the wires make sure you add enough slack so it doesn't get stressed this time :D -------------------------------------------- Do you know if the 18920 (5 piece kit) includes the same die that comes on the Tool Aid 18930, which is specifically for "weatherpack" terminals? |
How about one like this?
It's made for crimping Molex connectors, and looks similar to what you need. You can also get different dies for other style crimps, too. I have a cheap D-Sub crimp tool from Radio Shack that I use to crimp small connectors, but it's not good for anything buffets than say 20 awg. Hope this helps. :thumbs: |
Thanks Fasthotrod!
I got some info directly from Tool Aid that wasn't on their website, and I ended up ordering the Tool Aid 18960 kit which includes 7 dies. Die 18922 is for 10-22awg weatherpack terminals. The 18960 was only $10 more than the 5 piece 18620 Advantages vs 18920 are: Two extra dies. [One does spark plugs wires.] Quick release mechanism to quickly swap dies (no screws). Longer handles for more leverage. They also have a new 18937 die (sold separately from either kit) for smaller 18-30awg weatherpack terminals, which I did not order and hopefully won't need. |
