AC/HVAC unit just plugs in. 3 connector, 2 or 4 screws.
Center console trim can be taken out in < 10 minutes if you've done it before--first time will probably take longer. Toughest part is getting the wires disconnected; traction control button is probably the toughest. |
AC Unit
Originally Posted by taken19
(Post 1592404050)
Correct. Pull the trim off, remove 2 mounting screws (maybe 4... Can't remember) and unplug. Pretty easy.
Originally Posted by NachosZO6
(Post 1579875732)
good write up.
I'm doing this now and I can't get the console up out of the way with the shifter in park. Do I have to take it out of park to get the console off?
Originally Posted by Jimmy W1
(Post 1592412902)
1) On the right side of the shifter, under the shifter boot, you can press down, and this should make it so you can move the shifter into neutral. https://cimg3.ibsrv.net/gimg/www.cor...589bef0f82.jpg 2) If #1 does not work, then you can get the console up as high as possible, get the leather boot moved up out of the way, and see if you can get something under to release the locking pawl to be able to shift out of Park. Some owners have tied back the locking pawl, without having to completely remove the console. https://www.corvetteforum.com/forums...k-finally.html Hopefully, this will help. |
Console on 2008 convertible
Does anyone know how to remove the console and radio trim on a 2008? The Oval shape covering the bolt and two screws does not exist on this model! Do you just pull hard and hope nothing breaks?
Post a picture. If there are no screws holding it on then I'd start pulling on it
Did it. Took a few hours. I had a hard time removing the cigarette lighter plug, and putting it back on. I appreciate the time you took to outline the fix here on CorvetteForum's, a big help. I also watched the YouTube video a few times.
Just did this....been putting it off for awhile as I heard it's a pita.....went VERY smoothly thanks to this thread....
Originally Posted by BATMAN32
(Post 1593440362)
How do the little gauge pod clusters (around Hud and trip buttons) remove? Can I just pry them off? Clipped on or screwed in from the back?
*nevermind....they are built in to the gauge cluster* |
Great instruction...just pulled mine out made it easy...thanks... going to get it painted body color....previous owner had fake carbon fiber wrap and installed with contact cement in some places....
I have to replace the TC button, this will help. Thanks
I'm glad I found this excellent write-up, since I have to replace the HVAC module in m y 2007 and mechanics around the SF Bay area want $200/hour. Thanks for taking the time to describe everything clearly and add in all the great photos. :thumbs:
