Center Console and Radio Bezel Removal
22 Attachment(s)
I know this has been covered before but I couldn't find any decent write-ups with pictures using the search function. Since I had to take console apart anyway on my 2007 coupe to install an iPod gateway I thought I'd document the process.
Disclaimer: Perform all work on your vehicle at your own risk. I cannot accept liability for any damage or injury caused by using the information in this writeup. Here are the tools I used: Attachment 48148852 Flat blade screwdriver with some electrical tape wrapped around the blade (to protect the plastic pieces). 3/8" drive ratchet 10mm socket 3" Socket extension 7mm Nut Driver T15 Torx Driver Paper clip (a small interior pick tool would be better) ________________________________________ _____________________________________ Lower your windows all the way. Disconnect your negative battery terminal. Attachment 48148853 Open the center console lid and remove the four T15 torx screws and set the console lid out of the way. Note: This step isn't absolutely necessary but it does give you a little more room to work and it only takes a few seconds to do so I'd recommend it. Attachment 48148854 Using either your fingernails or a wrapped flat blade screwdriver remove the plastic caps at the rear of the center console. Attachment 48148855 Remove the two 10mm nuts that were under the caps at the rear of the center console. Attachment 48148856 Using a wrapped flat blade screwdriver pry up on the oval shaped plastic trim piece at the front of the center console as shown. Note: If you have the F55 suspension option you'll have a wiring harness to disconnect underneath the oval piece. Attachment 48148857 Attachment 48148858 Remove the 10mm bolt that is underneath the oval shaped trim piece. Attachment 48148859 Remove the two 7mm screws at the front of the center console. Attachment 48148860 Pull up on the passenger side of the E-Brake boot. There are three clips that hold the boot down that you'll have to pop loose. Do so carefully and pull the E-Brake boot up as shown. Attachment 48148861 Remove the two 7mm screws that were exposed when the E-Brake boot was moved out of the way (shown below). Attachment 48148862 Attachment 48148863 Carefully loosen the plastic trim piece that follows the radio bezel on the passenger side of the car. You don't need to take it all the way off, just loosen it as shown. Attachment 48148864 Lift the back of the center console off of the studs in the rear and slide it back towards the rear of the car. It may take some maneuvering to get it around the E-Brake boot. Pull the shifter boot in toward the shifter lever to release the plastic tabs from their slots in the bezel as shown. Attachment 48148865 Attachment 48148866 Carefully pull the bezel up and away from the dash a few inches. There are several clips that hold it in on either side of the radio so it will not come out super easily but you shouldn't have to be superman to get it loose either. If it feels like it's not turning loose make sure it's not caught on something. Once there are a few inches of clearance between the bezel and the dash disconnect the wiring harnesses that connected to the back of it. Mine had two heated seat harnesses, a cigarette lighter harness and a hazard switch harness at the very top. Attachment 48148867 Attachment 48148868 Once you've disconnected the connectors at the back of the bezel rotate it so the top of it goes toward the passenger seat and disconnect the remaining two wiring harnesses toward the back of the piece. The Active Handling/Traction Control connector is pretty much self explanatory. There is a plastic piece on the side of it that you gently pry up that will allow you to disconnect it. The cigarette lighter connector was the single worst part of this job. It took me a few minutes of looking/feeling to figure it out. There is a hole at the very top of the female end of the connector that the male end clips into holding it in place. The only problem is that the aforementioned hole is located at the very top of the connector facing the underside of the bezel... WTF GM? Anyway you'll need a tool like this one: Attachment 48148869 or a short interior pick to stick down in the hole and release the clip holding the harness in place and pull back (toward the dash) on the harness at the same time. Here is the connector disconnected. The part facing the camera is pointed up (facing the bottom of the bezel) when installed. Attachment 48148870 Attachment 48148871 Set the bezel aside. Attachment 48148872 This is what you're left with in the car. If you want to remove the radio and the A/C head unit just remove the six 7mm bolts and pull them out. You'll have several wiring harnesses in the back to disconnect as you go but there is plenty of slack in all of them. I didn't get pictures of this step but it's pretty intuitive. Attachment 48148873 Reverse the steps above to get everything back together. Don't forget to reconnect the hazard switch at the top of the bezel... that one's easy to forget. |
That is a really good write-up.
After doing mine, more than once, the one tip I would add is that when re-installing the lower console (bottom part of glove box) is to make sure it is pulled all the way back when tightening the two rear nuts. This will allow the radio bezel to sit down better and align better with the lower console where they meet. |
Nice write up. Did mine many times and by coincidence twice today. (don't ask). The only thing I would say is I don't see the need to remove the 10mm bolts at the rear of the console.
:thumbs: great write-up
Thanks :cheers: |
Nice.
I would add a small addendum to this. If you only need to get the bezel out of the way and not remove it totally (as in replacing a shifter or the like) you can avoid messing with the lighter connectors and (if I remember correctly) the aux power connector and the traction control switch connector by simply disconnecting everything else and then carefully rotating the entire bezel into the passenger footwell. The wires are long enough to handle it. Be sure to wrap the bezel in a towel or something before you do this as the bezel has some sharp corners that can scratch the dash and glove box. Eliminating three connector battles is a nice thing. :yesnod: Z// |
:cheers:
1 Attachment(s)
Thanks!! This will help a lot, I removed my console about two months ago. I had my friend wrap it with 3m Di-Noc while I had some trans work done. Now it will be a lot easier putting it all back together!
Attachment 48148850 -Carl |
You left out the two screws on the side, adjacent to the e-brake lever. In your pictures, you show those two already out. Extra warning on those as I found out the hard way, they are really easy to drop and disappear down into places/parts unknown...I still haven't found one of mine. All else is good. This center console is a PITA to remove and install whereas the C-5 is easy. No clue why they had to make it so difficult.
Originally Posted by FireRoc
(Post 1579870269)
Originally Posted by realcanuk
(Post 1579870325)
Originally Posted by dgrant3830
(Post 1579872511)
Thanks for the kind words guys. I was surprised there wasn't already a write-up like this in this section. I found a few old ones when I searched but the pictures aren't hosted anymore. :rock: |
good write up.
Great instructions. So you don't have to remove the shifter knob to remove the bezel????
If that's the case I have plans for my stereo system. |
Great write-up. Thanks for taking the time to document it for us.:thumbs:
:lurk: thank.. Getting ready to pull mine soon.. :lurk:
Originally Posted by sh2002
(Post 1579877536)
Originally Posted by cdkcorvette7
(Post 1579881911)
Nope, no need to remove the knob. If you have an auto you might want to shift into neutral and set the ebrake when you start. I'm not sure if you'd have enough clearance to slide the bezel up and over it if you're in park...
Great instructions. However, Im still uncomfortable with doing this myself. Im on Long Island and was wondering if someone local would be able to lend a hand with installing mine.
Originally Posted by ricknyc23
(Post 1579886443)
Try one of these: http://www.licoa.org/ http://www.longislandvettes.com/ http://www.corvettelegends.com/clubs/ny.htm |
(Post 1579872511)
(Post 1579873014)
There's a step in the write-up to remove them, but you're right, I neglected to include a picture of them before removing them. I think I actually did take a picture of them before removing them though. I'll check tonight and add it if I did.
Thanks. Im already a member of one. I was gonna ask one of those guys too.
(Post 1579888341)
You almost definitely have a local corvette club over there. Look them up and I'm sure someone will help you out...
(Post 1579888397)
Pics of this step have been added. :thumbs:
