power antenna w/ cb 1978
looking for a power antenna w/cb my is not working it has power but will not go or down:flag:
If it sounds like it is working, it probably just needs new Antenna Mast Repair Kit. It is very easy to install. Have a great one. Gene
Originally Posted by doctorgene
(Post 1579725330)
1978 corvette power antenna w/cb
the motor go on when you turn the radio on how do you get the antenna off the weel is in the way:flag:
Yes Sir; first, set car up on stands, Unhook battery. You have to remove the driver's side Exhaust piping & muffler, sometimes you have to have a new stainless steel band, or two, to reinstall this piping. It does help to remove the wheel. The wire loom plug is behind the rear driver's side rear speaker. Gently pushing out the rubber wire plug, to the outside.. Now look at the bolts holding it to the body, will help if you spray Wd or another brand on all bolts, first, this will ad in removing them. Buy A Corvette shop Manual from or made by Helms. This will give you all the info. you will need to do this job. Be Safe, Have a great day. Gene
78 power antenna w/cb
thanks for the help lou:flag:
Originally Posted by mrpacecar
(Post 1579724361)
found one
leedid1406
Originally Posted by MN81C3
(Post 1580623379)
Are you still looking for a AM/FM/CB antenna? I have a spare.
I'm looking for one |
Power antenna for a 1978 Corvette Pace Car
Hi,
Can somebody help me with a power antenna for a 1978 Corvette Pace Car. It's a AM / CB radio. |
still looking
still looking for a antenna... a 1978 am/fm for my pace car...if you have one for sale please pm me
thanks |
CB antenna
(Post 1580623379)
Thanks, Nick |
Yes Sir; I have a AM / FM / CB radio w/Out the antenna. The antenna's are more money, than the radios, or just as much. I need an antenna for a 1982 W/ CB AM / FM Or sell the radio. I have the divider that came with it. It was working when I took it out. Thank's Gene
78 CB antenna mast.
Trying to find the mast cable which is all one piece with the mast is not going to be easy. Don't bother going to GM you won't find it and can't get it in repo. Once you have the antenna on the bench, you have to remove the grayish colored plastic cover, 4 screws. If the cover is black the antenna has been replaced already. It is sealed with a whitish colored silicone as a sealer for the motor. You have to get the broken nylon mast section out, or it will jamb the new mast. The good news is I have found that sometimes in icy weather ice forms around the bezel on top of the rear fender and the mast won't work. If you turn the radio off with ice around the bezel it may have just jumped the track on the motor winding pulley inside and its not broken. Slim chance but I have seen that before. You can get a 79 mast section only but the tip is different than 78, and the 79 comes with what looks like a fishing hook on the end and has no way to attach to the motor in the 78 antenna.I always wanted to try the 79 style just cutting off the fishing hook but haven't tried that yet so I can't say that would work.If you don't find one I have quite a few here standard and CB.
I am looking to purchase a complete 1978 CB power antenna, any help would be great.
Tomjacksonn@live.com Thanks |
Originally Posted by Tomjacksonn@live.com
(Post 1592418461)
Tomjacksonn@live.com Thanks anyone have a power antenna w/cb for an 82? |
Are you looking for original equipment ? I think that is all that i would have. If your interested send me a PM and over the weekend I'll look, Joe
Guys, posting to a 2012 thread with various requests isn’t the way to go. If you have parts available, please start a For Sale thread with asking prices. If you are looking for parts, please start your own WTB thread. Don’t post in someone else’s. |
