Npp?
Is it safe to assume my 2012 GS 3LT has NPP exhaust? In winter storage & cant get to glove box.
Tx, Ken |
Only if it was ordered that way.
NPP is an option regardless of interior level chosen |
NPP is on option of 3LT.
Have to ask the dealer if all of his 3LT's have NPP. |
NPP is a stand alone option and has nothing to do with trim levels! You can have a 1LT with it or a 4 LT without it!
Originally Posted by Supersonic GS
(Post 1579673463)
Look at the pipes, you'll see valves inside them. |
It will be listed on window sticker.
I would think if it had it though, you would already know(no disrespect intended):thumbs: Bert Roll Tide! |
The butterfly valve at the tailpipes will tell you for sure. If you're still unsure, start it up. If you rev it up past 3000 rpms and the exhaust suddenly sounds meaner... you have NPP.
Originally Posted by ladder13
(Post 1579673503)
:iagree: :yesnod:
If you can see the actuators on top of the inside tubes, and the baffles inside them, tne you have the NPP exhaust. As others pointed out it is a standalone extra cost option.
http://image.vetteweb.com/f/9002745/...PP_exhaust.jpg |
Yup, the valves are there! Thanks all! Ken
(Post 1579673463)
Originally Posted by kmthor00
(Post 1579673629)
(Post 1579673629)
...now you need to install a M2W so the NPP can be controlled on-demand ! |
Originally Posted by Gary '09 C6
(Post 1579674677)
(Post 1579673602)
Pipes at the rear? Unfortunately i only put 11 miles on it before storage! Tx all
(Post 1579674677)
