Front Air Dam
I have broken 3 left hand sections and one center sections in the last 18 months. Is there any replacement parts that anyone has heard of that are not so brittle and would last?....
cut bout 3/4" inch off the bottom , wont hit so much
Front Air Dam
Thanks. That was my next step. I guess no one is making a more pliable alternative.
My '90 Vert has been pulled up on a flat bed at least 6 times in the last year and I saw the cable pushing the air dam back at least 30 degrees with no damage. This with the original parts. I guess its the luck of the draw.
Originally Posted by oldalaskaman
(Post 1579633128)
Next time your cars up on a lift, get a hold of a cut off wheel and cut away. i used 3/4 wide masking tape for a guide |
Originally Posted by mickey5
(Post 1579633543)
Do you have the center support bracket on? After installing the bracket [avail. @ a dealership for about 20 bucks ] I pop riveted all 3 pieces together .Hope this helps.
SLow down, don't hit the curb as hard.
What year and do you have Z51?
On my '86 the Z51 air dam is 1" lower than the stock one. |
Originally Posted by kleptopigdog
(Post 1579638605)
Originally Posted by mrmtrtrnd
(Post 1579638559)
6 times in a year :ack: Wow sorry to hear that. :(
Finally found a Vette savvy tech at a Chevy dealer far from home who found two injectors intermitantly failing when they got too hot ( soaking up the heat when shut off). Unbelievable. One guy even wanted to sell me a rebuilt engine.I was going to get rid of it as a junker but thankfully persevered. |
1 Attachment(s)
Here is one I have for sale if you are interested:
For Sale - Right Front Spoiler for 1984-1990 Corvette - Deep Z51 version; fits 1985 2nd design; fits 1986 All and 1987-90 with Z51 performance handling option. $14 shipped to US location. |
Originally Posted by l98tpi
(Post 1579639218)
Originally Posted by clarkbalt1
(Post 1579632655)
However let me qualify that statement by saying that I've been looking at ones for the 92 - 96 cars. The earlier ones may indeed still be available in the more flexable material. |
(Post 1579642886)
Drove Vert for 20 to 60 minutes...everything normal. Shut it off and could not restart. If you waited several hours it would start right up and run normally until it happened again. Towed it to several "experts" who could not find the problem...
