c5 leaf springs stock z06 vs T1 ride height?
Is there an appreciable ride height difference? Thinking of trying some T1's I have.
Please don't side track into coils, thanks. No "guesses" only post in if you have done it or have done some kind of measuring or analysis to back up. Yes I know there are adjusters, just want to know what the spring will do to ride height, thanks! :thumbs: I searched & did not find much. |
Yes, the T1 springs allow you to lower the ride height much more than stock springs.
:thumbs:
Calculate it. You know corner weight, you know spring rates, ...
Originally Posted by gkmccready
(Post 1579507984)
And I'm not even sure it factors in to ride height, does it? Or is it just rate? When I was changing springs on my 96 lt4 there was more than an inch height difference in the unweighted spring heights. There are dozens of different springs (factory & aftermarket) for the c4 & it was an ongoing discussion due in part to lack of information about which springs to use on c4's. The t1 spring rates ARE higher RATED, but early indications are that the car sits lower on them. How can that be unless the unweighted curve also plays a part? :thumbs: |
Originally Posted by froggy47
(Post 1579508842)
The t1 spring rates ARE higher, but early indications are that the car sits lower on them. How can that be unless the unweighted curve also plays a part?
When I made the change, the T1 set up was about 1" lower then then stock. Before corner weighting
Originally Posted by AU N EGL
(Post 1579509792)
:thumbs: |
T1 will probably be flatter. Here are some pics of a C5 ZO6 spring vs a C5 Z51 spring (rear).
http://i69.photobucket.com/albums/i5...s/7852a8f9.jpg http://i69.photobucket.com/albums/i5...s/957a885a.jpg |
Thanks!
Yes, the T1 spring was much flatter than the stock spring when I compared them side to side. :cheers:
However, I bought an old T1 kit off somebody else so maybe it was flattened out a bit when I bought it LOL. |
