*SALE* XSPower C5 Longtube Headers on sale 9/28 - 10/4
XSPower Longtube Header Systems. For Corvette Forum members :cheers:
You can order direct from the website at: CLICK HERE TO ORDER Also check us out now on Facebook for all the latest specials and product updates! http://i6.photobucket.com/albums/y23...booklogo-s.jpg $25 off when you "Like" us on Facebook and use the Coupon Code found in the News Feed! :thumbs: Catted systems- $924.99 shipped Offroad systems- $774.99 shipped *Add a XSPower C5 2.5" Catback for a complete engine-tip system for just $550 more :smash: XS Power Longtube headers / X-pipe -Made of high quality 321 Stainless Steel -Polished to a chrome like finish -1 3/4" Primaries -No O2 extensions required! -Wideband bung in the X-pipe -Available in either High Flow 220 cell cats or for Off-Road use -3" X-pipe necked down to 2.5" at the very end to mate to most all catbacks! -3" Lap Style Band Clamps Included! -Header gaskets Included! -01-04 AIR fittings with block-off plates Included! -97-00’s can change to the 01-04 passenger AIR tube, modify their current tube if you want to keep AIR, or use the SUPPLIED block off plates and delete AIR. -Flanges are thick 7/16" and welds are gorgeous -Spiked Race merge collectors! -Complete all the way to the stock catback location! http://i6.photobucket.com/albums/y23...r/DSC02452.jpg Check here for customers who have the product and their thoughts along with install input/questions! https://www.corvetteforum.com/forums...er-thread.html -Drivers side header slides right up and in from the bottom. -Passenger side all that is needed is to drop the starter and it will slide right up and in from the bottom as well! http://i291.photobucket.com/albums/l...a/DSC00315.jpg http://i291.photobucket.com/albums/l...a/DSC00026.jpg http://i291.photobucket.com/albums/l...a/DSC00025.jpg http://i291.photobucket.com/albums/l...a/DSC00019.jpg http://i291.photobucket.com/albums/l...a/DSC00100.jpg http://i291.photobucket.com/albums/l...a/DSC00097.jpg http://i291.photobucket.com/albums/l...a/DSC00098.jpg http://i291.photobucket.com/albums/l...a/DSC00317.jpg http://i291.photobucket.com/albums/l...a/DSC00318.jpg http://i142.photobucket.com/albums/r...s/DSC03261.jpg The CATs are metalic core European 110 cell units, VERY free flowing and legal! As a matter of fact, during testing the difference between the CATted versus NonCATted systems were negligable; http://i142.photobucket.com/albums/r...s/DSC03267.jpg Clearences are very good all around, the primary O2 sensors are fine; http://i142.photobucket.com/albums/r...s/DSC03294.jpg http://i142.photobucket.com/albums/r...s/DSC03295.jpg No issues with Sparkplugs; http://i142.photobucket.com/albums/r...s/DSC03298.jpg http://i142.photobucket.com/albums/r...s/DSC03301.jpg http://i142.photobucket.com/albums/r...s/DSC03296.jpg http://i142.photobucket.com/albums/r...s/DSC03309.jpg http://i142.photobucket.com/albums/r...s/DSC03307.jpg http://i142.photobucket.com/albums/r...s/DSC03311.jpg http://i142.photobucket.com/albums/r...s/DSC03308.jpg http://i291.photobucket.com/albums/l...a/DSC00878.jpg http://i291.photobucket.com/albums/l...a/DSC00859.jpg http://i291.photobucket.com/albums/l...a/DSC00865.jpg Here is the process I followed to remove my stock exhaust. I just made some notes of what I did and put them together for any of you that may want some direction of how to get the stock exhaust off. This is what I did! 1.) Disconnect negative cable from battery. 2.) Remove Oil Fill cap and Fuel Rail Covers http://i291.photobucket.com/albums/l...a/DSC00030.jpg 3.) Remove spark plug wires from coil packs, simply pull out. http://i291.photobucket.com/albums/l...a/DSC00031.jpg 4.) Having another buddy to tackle one side of the engine bay while you tackle the other is very beneficial/time saving if you can trust their work! http://i291.photobucket.com/albums/l...a/DSC00037.jpg 5.) Disconnect connection on both coil packs. http://i291.photobucket.com/albums/l...a/DSC00034.jpg 6.) Remove bolts connecting coil pack brackets to valve covers (10mm) http://i291.photobucket.com/albums/l...a/DSC00035.jpg 7.) Remove coil packs on brackets from the valve covers. http://i291.photobucket.com/albums/l...a/DSC00039.jpg http://i291.photobucket.com/albums/l...a/DSC00043.jpg 8.) Remove oil dipstick tube on passenger side. (10mm bolt on manifold) http://i291.photobucket.com/albums/l...a/DSC00048.jpg 9.) Disconnect AIR fittings from manifolds on both sides. http://i291.photobucket.com/albums/l...a/DSC00046.jpg http://i291.photobucket.com/albums/l...a/DSC00049.jpg 10.) Remove the accessory belt 11.) Remove alternator from bracket (2 large bolts) set alternator aside http://i291.photobucket.com/albums/l...a/DSC00075.jpg 12.) Safely raise vehicle leaving enough room to work under. http://i291.photobucket.com/albums/l...a/DSC00050.jpg If you do not have access to a lift, refer to owner’s manual for proper instructions on lifting your Corvette. 13.) Remove 3 nuts/bolts on each side connecting the stock H-Pipe to the manifolds http://i291.photobucket.com/albums/l...a/DSC00051.jpg 14.) Remove the 2 bolts holding the stock H pipe up to car http://i291.photobucket.com/albums/l...a/DSC00053.jpg 15.) Remove O2 sensors in the H pipe, leave harnesses connected http://i291.photobucket.com/albums/l...a/DSC00055.jpg 16.) Remove 2 bolts per side connecting stock H pipe to your catback http://i291.photobucket.com/albums/l...a/DSC00057.jpg 17.) Support the H pipe while you remove the last 2 bolts connected to the spring mounts which will allow the h pipe to be removed http://i291.photobucket.com/albums/l...a/DSC00058.jpg 18.) Remove the H pipe http://i291.photobucket.com/albums/l...a/DSC00061.jpg http://i291.photobucket.com/albums/l...a/DSC00064.jpg 19.) Disconnect O2 sensors at the ends of each stock exhaust manifold 20.) Relocate to top of vehicle in engine bay 21.) Remove 10mm bolts connecting the manifolds to heads http://i291.photobucket.com/albums/l...a/DSC00047.jpg 22.) Remove stock exhaust manifolds out the top http://i291.photobucket.com/albums/l...a/DSC00068.jpg http://i291.photobucket.com/albums/l...a/DSC00073.jpg 23.) Now is a great/easy time to remove sparkplugs if you choose install new ones at this time. 24.) Your stock exhaust system is now removed! 25.) Move back under the vehicle 26.) Remove the 2 bolts holding starter to the block on the passenger side along with the 2 nuts holding the electrical connections. http://i291.photobucket.com/albums/l...a/DSC00070.jpg 27.) Remove the starter wiring *note what attaches where* 28.) Remove the starter 29.) Place the passenger side header up into place, do not bolt down. 30.) With the header up into the engine bay now, slide the starter over the collector. If the header wants to fall out, having someone hold it here works well. *It is a tight squeeze, so try a few different angles and may have to give it some muscle. Also there are a couple wires and a ground strap that may hold you up, so make sure you don’t get hung up on these. Sometimes removing the ground straps on both sides helps, just reattach to the block after the headers are in place *Check your header clearances here first and make sure you have clearance in the tight areas to the steering shaft on the driv. Side and your AC Line on the pass. Side. If the clearance is tight, you can make a tiny dimple to gain clearance if you like, or you can use a file to trim away some material as well. 31.) Re-attach wiring to the starter with the header up into the engine bay but still completely unbolted. 32.) Bolt the starter up to the engine with the header still loose. 33.) With the header still loose, install your front O2 sensors 34.) Now bolt the header down to the engine, still leaving somewhat loose for fitment. 35.) Headers install from the BOTTOM 36.) Install drivers side header from the BOTTOM. 37.) Before bolting the header to the engine, install your front O2 sensor. 38.) Bolt the drivers side header to the engine, leaving somewhat loose for fitment. 39.) Fit the X-pipe up into the header collectors. With help, have someone hold the X-pipe while you re-install the rear O2 sensors and complete the next few steps. 40.) Use Copper Spray Gasket on the ball and socket flanges of the header collectors and X-pipe, loosely bolt the X-pipe to the headers. Using high-temp thread locker on these bolts is recommended. 41.) Moving back, slip the mid-pipes over the X-pipe and hang using the factory spring mounts. 42.) Connect the rear mid-pipes to the catback, don't forget the gasket! 43.) Moving forward, tighten the headers down the engine using proper torque and torquing method. 44.) Tighten the X-pipe down to the header collectors ensuring EVEN tightening to both side to draw the X-pipe in straight to prevent leaks. 45.) Install clamps to the X-pipe to Mid-pipe connection and tighten. 46.) Tighten the Mid-pipes down to the catback 47.) Go over all connections making sure they are properly tightened with everything aligned. 48.) After a heat cycle of the system, it is recommended to re-check all connections to make sure they are tight as the heat with expand the system. 49.) Re-install all factory items such as dipstick, plug wires, coil packs, alternator, and anything else that may have been removed for the removal of the stock system or the install of the new system. -Jon You can order direct from the website at: CLICK HERE TO ORDER |
Good deal for good quality header. The go on easy and don't leak!
PM Sent
Originally Posted by futuretech
(Post 1579375320)
Originally Posted by customizer
(Post 1579377284)
PM Sent
Payment Sent....
(Post 1579380289)
Payment Sent....
:cheers: |
Thanks for the orders, you will receive shipping/tracking information via your e-mail :thumbs:
:cool:
My set won't be on until next week, but they look great!
Systems are ready to ship out same/next day to get there in time for the holidays!!! Earlier you order, best chance of it getting there in time :thumbs:
Originally Posted by Superman09
(Post 1579440944)
(Post 1579445454)
Shipping is fast to Hawaii and great looking set......:rock:
Get your orders in ASAP to ship for Christmas! In stock and shipping daily! :smash:
:cool:
Just purchased a set.
Originally Posted by JasonSB
(Post 1579487983)
Thanks! |
Get your orders in NOW to get them before X-Mas! :smash:
All orders have SHIPPED! :thumbs:
(Post 1579492984)
Received and shipped :cheers:
Thanks! Installing them the next couple of days.. |
(Post 1579519413)
Got them. Very fast shipping :)
