L88 Hood scoop
I have decided instead of fabbing my own, i will just add an L88 scoop to my hood and graft it in properly this winter. I have seen several on the internet, but does anyone here have experience on where I can get a good quality glass one so I can cut my hood and graft it in place? Looking to gain a few inches in height and be able to use the cold air functionality if I want to. Thanks! Jeff
you might think twice about that, it is very difficult to to complete the glass job,
without after effects of ...cracking around the joined areas over time. buy a hood their avaliable. |
Originally Posted by 69Vett
(Post 1579349061)
Here is a link to a thread I started with the L88 hood scoop I installed. Follow the thread down for more details
http://forums.corvetteforum.com/c3-g...-l88-hood.html :thumbs: |
i just did my hood and its not hard if you can do body work ,,
first vette bond the scoop to the hood and screw it down after the vette bond is hard remove the screws fill screw holes with vette bond then flip the hood and cut the under side out ,, \ lay fiberglass mat across the hole under side of hood and scoop my your scoop thicker ,, need heat to alot of heat ,,so the resin drys thats the thing is resin drying .. and flip the hood and do the same ,, i dont know how to put pics in this form so look under my pics |
Originally Posted by sheldonbaker
(Post 1579353146)
first vette bond the scoop to the hood and screw it down after the vette bond is hard remove the screws fill screw holes with vette bond then flip the hood and cut the under side out ,, \ lay fiberglass mat across the hole under side of hood and scoop my your scoop thicker ,, need heat to alot of heat ,,so the resin drys thats the thing is resin drying .. and flip the hood and do the same ,, i dont know how to put pics in this form so look under my pics there will be no 10 hr work to fit////// like you will a aftermarket hood they dont fit right at all just take your time i have about 4 days working on it h and about 7 hrs |
I have a long l88 scoop for sale if you're interested.
Be careful what you use. Your car is SMC and most hood scoops are fiberglass. You need a special bonding agent and filler so you don't have cracks or have the seams "reveal".
You might want to consider getting an older hood to add the scoop to. |
Originally Posted by Curby
(Post 1579356557)
Originally Posted by bluegtp
(Post 1579354795)
I'm adding an L88 scoop right now. I bought the Eckler's scoop for $219 (less than $200 after 15% discount). Costs more but contour of scoop matches hood exactly so the fiberglass work is easier and the end result looks better. Fiberglassing a scoop is not very hard to do. In my opinion, easier than getting an aftermaket hood to fit. Done right, it will never crack.
I use body filler instead of screws to temporarily mount the hood before fiberglassing the back. Easy to knock off the body filler later and no holes to fill. |
Originally Posted by Clubby99
(Post 1579361702)
(Post 1579361702)
Originally Posted by flynnd_33
(Post 1579366292)
what year is your car? im having a hard time finding a L88 scoop for the long hoods i have found plenty that work with short hoods that just stop flat next to the wiper door but none that contour next to the windshield for long hoods. maybe im just looking in the wrong place. u think someone would make them.
Custom Image Corvettes (507) 581-3076 I have 2 of the long L88 hoods, but they are in Orlando being bonded together and trimmed out by a friend. Depending on how they fit, I may use one and sell the other one on ebay. I am afraid these are the ones that don't fit very well. My first test-fit was OK, but it looked like it needed some work to look right. http://i607.photobucket.com/albums/t...epaint13-1.jpg http://i607.photobucket.com/albums/t.../repaint26.jpg http://i607.photobucket.com/albums/t.../repaint10.jpg http://i607.photobucket.com/albums/t.../repaint11.jpg http://i607.photobucket.com/albums/t.../repaint12.jpg |
(Post 1579349061)
Originally Posted by yellow 72
(Post 1579366948)
So you're saying fiberglass can't be properly repaired....who would have thunk it. .:leaving:
(Post 1579367107)
It is true, Fiberglass and SMC are very hard to bond together without the seam revealing itself later. They expand and contract at different rates. It is much easier to buy an aftermarket hood and do the necessary bodywork to make it fit the car. it just costs more.
(Post 1579367107)
position the scoop on the hood, scribe the outline with a marker, then make a groove in the hood's glass (i used an electric drill with a sanding disc) and thin the bonding surface of the scoop from the underside. that will give you a feather edge instead of a butt edge. use epoxy and screws to set the scoop inplace, then add a few layers of glass cloth to reinforce, and finish with body filler. it will be nicely contoured and strong. see "my rat" in my garage for the finished product.
(Post 1579354795)
