Where do the brake pad clips go?
I am about to install a set of GM performace front brake calipers & pads. The pads came with a bag of hardware. I know where 4 of the clips go - each end of the abutment brackets but there are 2 other clips. I believe they are squeal clips but I can not tell where they go from the instructions provided. Can ayone provide a picture or explain in detail where this clip goes and what it does? Is it really necessary?
Originally Posted by Bowtieguy54
(Post 1579165195)
Originally Posted by cdkcorvette7
(Post 1579165949)
If they are what I think they are they clip to the brake pads positioned such that the piston contacts the metal guard instead of the back of the actual pad. Do you have a picture?
The third clip goes on the inside of the caliper. Look at it and you will see two small "arms" about 3/16" long pushed out from the rounded side of the clip. These locate the clip on the inside of the caliper. It will snap in place with a little pressure. This clip keeps the pads pushed all the way down and help alleviate squeel.
Originally Posted by CHJ In Virginia
(Post 1579166914)
Very nice explanation - thanks for the help! |
just pop the other wheel off and look at it for guidance...:thumbs:
Hello I hope I haven't missed the boat on this thread. I am replacing the front pads and calipers on my 86 there are abutment clips that came with the hardware kit I am having the same issue as the original post here. I cannot for the life of me figure where these clips go. I pulled the other side off and both sides did not have these. If someone can please help I would appreciate it.
