Reset change oil light on C5
I forgot how... Help?
Re: Reset change oil light on C5 (Wht98)
PRESS TRIP BUTTON ON DASH TILL DIC READS "OIL LIFE REMAINING --%"
THEN HOLD RESET BUTTON FOR A FEW SECONDS . :cheers: |
Turn the ignition on but don't start the car. :cool:
Bring up oil life % on the DIC. :D Push reset, it should go to 100%. :smash: Start it up and listen to the CORSA's purr :cheers: |
Here is a "cool" way to do it posted by CARPE DM
Put key in the "on" position and pump the gas pedal three times. It was designed this way to help avoid another grease smear on the dash by the oil changer. |
I tried to reset my oil percentage as is stated above but mine doesn't go to 100%, after hitting the reset button as stated it shown ---% and then when I go back and start the car it goes back to it's original 42% oil life left. Any thoughts???
Originally Posted by z71paul
(Post 1585450976)
http://forums.corvetteforum.com/c4-g...t-working.html |
(Post 1585450976)
1. Turn the ignition to ON, with the engine off. 2. Press the TRIP button so the OIL LIFE percentage is displayed. 3. Press RESET and hold for two seconds. OIL LIFE REMAIN 100% will appear. Are you holding the Reset button long enough? |
