LS2/LS3 failures
I have been reading over on the Z06 forum that there is something wrong with the LS7 motor. There have been 25 reports of failure on stock motors, split about half and half for exhaust valve failure and what looks like bearing failure due to lack of lubrication. One of the arguements put forward is that this is a significant number of failures for the valves and that there isn't a correpsonding number of LS2/LS3 failures therefore the LS7 is flawed. My question to the LS2/LS3 community is how many stock engine failures is this community aware of? Any info would be appreciated.
I have a 06 z06 I'm on motor #2 dropping valves...I don't think its an ls2 or ls3 issue
Originally Posted by z0sicktanner
(Post 1578789497)
Sorry to hear about your problems though. |
I killed an LS3 bolton only at 71K miles. It was really hard to tell the first point of failure, but a serious overrev was caused by the rev limiter being set way too high by a traveling tuner.
There were no broken springs, but there were bent pushrods, and a headless intake and exhaust valve. The residual damage included a broken rod, two disintegrated pistons, a couple of badly beaten heads, and a missing chunk of cylinder wall. As a guess, I'd say one of the valves lost it's head first. :D |
Originally Posted by achilds
(Post 1578789135)
http://www.g8board.com/forums/showthread.php?t=21450 http://ls1tech.com/forums/esp_search...v-bar&type=all http://ls1tech.com/forums/esp_search...v-bar&type=all http://www.facebook.com/media/set/?s...8&l=c488e47454 And there must be more at other forums for the LS2/3... :salute: |
(Post 1578789702)
I am just curious as to the number of LS/2/3's failing. The postion that 13 occurrances of dropped valves on stock motors is reason to panic just doesn't sit well with me. .
Remember this...how many owners MANUALLY over rev the car by downshifting or mis shifting, and are not admitting to it. Or how many times do you think that happened on the motors that failed? You can manually over rev the motor and not have failure at that time, it can crack a valve spring or bend a valve and not "let go" until a later date..... |
(Post 1578789497)
Originally Posted by m R g S r
(Post 1578790660)
So there have only been 13 failures, out of how many made?
Remember this...how many owners MANUALLY over rev the car by downshifting or mis shifting, and are not admitting to it. Or how many times do you think that happened on the motors that failed? You can manually over rev the motor and not have failure at that time, it can crack a valve spring or bend a valve and not "let go" until a later date..... 13 stock motors reported on the forum. 27,000 made, but the arguement is not all are on the forum. There is about 2 or 3x that many, but they were modded. |
That's an interesting point, did these LS2/LS3 (and even LS7) failures happen on bone stock vehicles that were just leisurely driving down the road?
Or were the owners riding them on the rev limiters for a few minutes or worse yet, using their own hand held tuning units/HP Tuners etc to actually raise the rev limiter on their otherwise bone stock valvetrains and taking their cars to 7500rpm? |
(Post 1578789135)
Originally Posted by LS1LT1
(Post 1578791127)
(Post 1578791026)
It isn't...I don't recall hearing about any (stock, unabused) LS2s/LS3s ever failing.
Hello,
My stock (Vararam only) 2006 LS2 motor blew at 20,000 miles. Headgasket failure led to #1 cylinder hydrolocking and exploding, connecting rod fell down and jammed against #2 cylinder and broke that connecting rod and shoved it throught the block! 1 year out of warranty and GM said sorry we can't help. :ack: Paid full price for new engine and installation at Gandrud Dealership in Green Bay. They did excellent work and car runs great! :cheers: Douglas in Green Bay :D |
A certain percentage of any motor will fail prematurely; and the percentage will go up the harder you run the motors, even if you don't actually violate the numbers by over revs, etc.
I don't know if the LS7 has a higher percentage of failures than the LS2/LS3, though it kinda seems that way. Only GM knows for sure. But the big question is, how much harder are the owners running those cars? |
It is also important to keep in mind that not ALL Corvette owners are members of the Forums, so there are a lot more actual failures, than those reported on the Forums that we read about.
(Post 1578789497)
(Post 1578791026)
