Sun Visor removal/replacement
Can any of you guys direct me to link for the sun visor removal and replacement? I know its here somewhere, I just cant find it.
Thanks!! |
Tips section has it all!
3 Attachment(s)
Sunshade Replacement
Removal Procedure Attachment 48150694 1.Tilt the sunshade down toward the windshield. 2.Insert a flat head screwdriver blade into the slot in the sunshade inner bezel. 3.Using the screwdriver against the elbow of the sunshade arm for leverage pull down on the sunshade arm while rotating the sunshade outboard until the sunshade stops. (the first tab disengages). 4.Push up on the sunshade and continue rotating the sunshade outboard until the sunshade with the inner bezel disengages from the mounting bezel. Attachment 48150695 5.Disconnect the electrical connector. 6.Remove the sunshade. 7.Disassemble as necessary. If removing the mounting bezel, pull the bezel from the garnish molding with your fingers. If replacing the inner bezel, remove the bezel from the sunshade shaft and press the new bezel onto the shaft. Installation Procedure Attachment 48150695 1.Route the harness through the mounting bezel. 2.Insert the mounting bezel into the garnish molding engaging the snap fingers. 3.Connect the harness to the sunshade electrical connector. 4.Push the connector up through the bezel and through the hole in the garnish molding. 5.Position the sunshade approximately midway between the windshield and the side of the vehicle. 6.Insert the rod with inner bezel firmly attached fully into the mounting bezel. 7.Rotate the sunshade toward the centerline of the vehicle until the sunshade locks in place. |
thanks guys, I found them....
Any threads on how to remove & replace the mirror on the visor? The bottom of the mirror doesn't seem to want to disengage
Originally Posted by Corvette505
(Post 1593083992)
or does the whole damn thing have to come down to be taken apart ? |
Just gently pry out the plastic lens and you can get to the bulb.
Originally Posted by AE Guy
(Post 1594564927)
Education
Originally Posted by 87SAM
(Post 1578759030)
Removal Procedure http://i53.photobucket.com/albums/g4...m/sunviser.gif 1.Tilt the sunshade down toward the windshield. 2.Insert a flat head screwdriver blade into the slot in the sunshade inner bezel. 3.Using the screwdriver against the elbow of the sunshade arm for leverage pull down on the sunshade arm while rotating the sunshade outboard until the sunshade stops. (the first tab disengages). 4.Push up on the sunshade and continue rotating the sunshade outboard until the sunshade with the inner bezel disengages from the mounting bezel. http://i53.photobucket.com/albums/g4.../sunvisor2.gif 5.Disconnect the electrical connector. 6.Remove the sunshade. 7.Disassemble as necessary. If removing the mounting bezel, pull the bezel from the garnish molding with your fingers. If replacing the inner bezel, remove the bezel from the sunshade shaft and press the new bezel onto the shaft. Installation Procedure http://i53.photobucket.com/albums/g4.../sunvisor2.gif 1.Route the harness through the mounting bezel. 2.Insert the mounting bezel into the garnish molding engaging the snap fingers. 3.Connect the harness to the sunshade electrical connector. 4.Push the connector up through the bezel and through the hole in the garnish molding. 5.Position the sunshade approximately midway between the windshield and the side of the vehicle. 6.Insert the rod with inner bezel firmly attached fully into the mounting bezel. 7.Rotate the sunshade toward the centerline of the vehicle until the sunshade locks in place. Searching for 02 C5 sun visor removal replacement assistance I found an excellent U tube video on removal. This thread is one for the books like most I've used. |
Originally Posted by km60sb@yahoo.com
(Post 1594815725)
...I found an excellent U tube video on removal...
Hey gang. I deleted the sun visors on my Trans Am and there were metal/billetdelete pieces that you could buy and screw into place so that there wasnt a big hole in your headliner. Is there anything like that for C5s? I want to take off my visors but I dont want big holes in the corners where they used to be.
Thank you sir!
I recommend replacing the inner bezel on the new sunvisor with the old one. It's easy to do with a pair of channelocks. Put one jaw on the tubing
(be careful of the wires) and the other jaw under the bezel, then squeeze. The bezel will pop loose. The channelocks can also be used to pop the old bezel onto the new visor arm. The reason for my recommondation is this... I could not get the visors to lock into place. They hung loose or fell back out. So I took a close look at what was going on. The problem is that the inner bezels are slightly different from the originals, enough to make them useless. The inner bezel diameter is larger than the indent where it's supposed to fit in the outer bezel. After I sanded the diameter to fit, it still would not lock into place. |
Had the same results with my Ecklers visors. OEM fit, aftermarket don't.
Mine also came from Ecklers. Some people posting didn't seem to have problems. I don't know if there's more than one manufacturer or their quality varies. I'm very satisfied with mine now that they are installed. But it took me several days to figure out how to solve the installation problem; It would be better if the manufacturer didn't include the inner bezel and explained in the instructions how to install the old bezel on the new visor. I could have had the job done in 5 minutes.
Originally Posted by steputt
(Post 1597859547)
Sun visors
Originally Posted by LAGary
(Post 1598052616)
I wish I read this earlier. I got the Eckler's replacement, seemed to fit okay so I tossed the old LH Visor and now it's really loose. Does anyone know an aftermarket that actually works? Thanks!
The second set I bought in March of 2018 were from buyavette_inc on eBay for $179.00. I installed them in March 2018 and the Black color matches the Black interior like factory. The quality of these are like a brand new GM product. The safety sticker looks lithographed or printed in the material somehow un-removable and permanent. These were delivered ready to install with new circular turn snap locks requiring no additional parts. These were E-Z out of the box installation and matched the car like OEM. Check these sun visors out and do your research. Call buyavette_inc and ask about the install lock rings. I know buyavette_inc visors were ready to install and play. I’ve owned my 02 C5 Vert 11 years. My only mistake was not joining Corvette Forum sooner. The projects I’ve done and the lessons I’ve learned from members here have saved me $$$$$$ and time. Thanks all members! Mule. |
(Post 1598052616)
