GM Performance LT4 Hot Cam Springs +
Installed but never run GM Performance LT4 Hot Cam with a set of GM Performance LS6 yellow beehive springs with retainers and locks. $300 shipped
Originally Posted by KO1
(Post 1578679894)
Does the kit have the cam, rockers, springs, valve caps, keys, shims? You say it was installed but not run, why? |
Cam, sprngs, retainers, locks only. Came in an engine I bought. Not enough cam for what I want to do
I have the LT1 HOT cam, a set of GM Performance beehive springs, Comp Cams chrome moly retainers, machined keepers $300 shipped. I also have a set of Trick Flow Specalites 1.6 ratio true aluminum roller rockers with 7/16" stud mount $175, Comp Cams hardened pushrods, studs and guide plates $60 everything is new and unused, the rocker arms, pushrods are still in the boxes.
(Post 1578868190)
3/8" studs ? |
7372-16 5/16" diameter pushrods. The rocker arms are for 7/16" studs. I will include the studs if needed
(Post 1578878366)
You would have had a sale otherwise |
Too bad they are 7.80's for non roller engines |
They are for a Vortec headed roller engine with 1.6 ratio TFS roller rockers.. Engine was measured w an adjustable pushrod and then pushrods were ordered
(Post 1578868190)
Originally Posted by 7secondsquarter
(Post 1578932075)
Wanna do an install? :D
Sure no problem It cant be a while you wait job though. Im old and slow so Ill need a couple days. |
(Post 1578932368)
Really like the way you think! Definate on the cam but am interested in your suggestion for a bigger project!! :rock::thumbs:
