can tuned ECU's be swapped between cars?
If I have an ECU that was tuned on my car, can it be swapped into another car and maintain the tune?
Originally Posted by turbotuner20v
(Post 1578676343)
The tune won't go any where in the ECU. It is in there until reprogramming happens. You could mail it to me and the tune is still in there. I can mail it back, same tune. To perform in another car is touchy. Even if the cars are identical, tunes might not be totally compatible between cars. You might need a tweak... Elmer |
Originally Posted by eboggs_jkvl
(Post 1578676360)
Elmer I'm selling the tuned ECU and want to make sure I'm listing it right. |
? :thumbs:
Nope....VIN needs to match
Originally Posted by Motorhead-47
(Post 1578690089)
PS, if you're selling it, you shouldn't be selling it with the tune as any sort of value. Without the VIN swap as a bare MINIMUM, the PCM is worth nothing more than a core. |
Originally Posted by edcmat-l1
(Post 1578690232)
Yep! This! With your VIN in the PCM, in another car, it won't even start.
