replacing rochester to edelbrock on 350
Hi Guys,
I have a rochester carb and thinking of replacing to edelbrock. Can anyone tell me what edelbrock model is recomended to my 77 automatic 350 vette? Do i need to replace the carb mount to do so? Thanks, A. |
You would need a 600 & another intake as there really is not enough room w/ adapter for a perf. setup. Al. intake & Holley rec.
I have a 1 " adapter under my Quad. with the dual snorkel intake on my 77. The air cleaner has a little less then a 1/4 " from hitting the hood. I also have a solid motor mount, so the motor does not move under acceleration.
So what, the adapter does not help stock auto. either! Closest point is at front of air cleaner.
An Edelbrock 1406 carb with an Edelbrock Performer EPS intake fit my 1979. I use a .2 Holley gasket between the carb and the stock dual snorkel air cleaner.Edelbrock claims that the EPS intake produces more power and torque than the Performer intake, and it is made for the Edelbrock carb so an adapter isn't needed between the two.
Originally Posted by la1234
(Post 1578505525)
Hi Guys,
springer89
Yes, the EPS intake is a good way for someone that wants to go square bore carb. w/ mild setup. |
Originally Posted by Ganey
(Post 1578506134)
I'm with "Mike" as go and change to an Edelbrock(Carter AFB upgrade), as know some here running well tuned Q-Jets willing to travel a bit to grab some easy street drag money. That's only if they slow down enough to actually have some idea where you are.
Originally Posted by Mike Ward
(Post 1578506292)
A change to an Edelbrock carb is not an upgrade in any sense of the word. Why do it?
(Post 1578506292)
Originally Posted by fauxrs
(Post 1578507295)
Based on personal experience 3Xs
I've given them a few tries and never liked them. If you absolutely need to swap out the Qjet, get a spreadbore Holly |
Originally Posted by qwank
(Post 1578507562)
:iagree:
(Post 1578506292)
Its the opinion from just about everyone I know and not even a choice when getting a carb.
I like Holleys, I can make them work just fine. I have a 600DP on mine now and it flat out rips!!!! When I got the car I had to take it apart and clean it out and change the power valve that looked to be blown for a 100 years, added non stick gaskets and adjust the needle and now I don't touch it. |
Why are you wanting to change the carb? What is the issue or symptom?
(Post 1578506292)
A well tuned Q-Jet (750 cfm) will shame an Edelbrock. |
Originally Posted by Tim H
(Post 1578510483)
Originally Posted by johnt365
(Post 1578510560)
I believe some more clarifications will be in place here: Have a 2601 edelbrock intake manifold with a stock, stutterer, nonfunctioning left Dizh, roachester carb. and need to replace or rebuild. rather put in a new one. considering putting an edelbrock to match the intake manifold. can obtain a roachester with holley inside (first time i've heard about it. is that for real??) or a 1406 edelbrock. can't get a holley here (Israel...). my mechanic recomend the edelbrock over the roachester. don't mind fuel economy, rather have more HP. any sugestions? |
(Post 1578552452)
any sugestions? If you can get an edelbrock carb I dont see why a holley would be unavailable but you certainly would know better. I'd go with the holley rebuilt q-jet if my only choices were that or an edelbrock. |
