Originally Posted by Rathmullan
(Post 1590700334)
My experience with a battery tender and a dead battery in my 2012 Vette is that the car's passive electronics simply use too much juice - with or without a hood lamp and the alarm activated - for the tender to charge the battery. I've always had to remove one of the battery cables before attaching the tender - in which case I've achieved a full battery charge within 48 hours plus or minus a few (temperature may affect the amount of time required).
If you have the luxury of time. Try this before fussing around with trying to figure out if your battery is shot. |
Originally Posted by grantv
(Post 1590700483)
I agree... but he probably figured this out 4 years ago. :willy:
Originally Posted by MSG C5
(Post 1578388791)
Thanks for all the replies! I purchased one of these bad boys and completely re-charged the battery in 3 hours! Since it's still down due to the interior being reworked, I re-hooked up my original trickle charger which is now showing the battery as fully charged.
This new unit also has a maintenance mode with the digital read out, however it takes up more space than the trickle charger. I'm glad I have it around the garage. :thumbs: http://i499.photobucket.com/albums/r...tuff/XC103.jpg |
I have seen that before also....a battery is dead and the trickle charger will not charge it...so I have hooked it up to a full size charger and charged that way and I have also pulled a battery before and take to the auto parts store and let it sit on their charger for a couple days.
Originally Posted by Stan MI
(Post 1578368747)
Don't know about your area but around here you can take the battery out and take it to an O'Rielys and they will put it on a tester for free (my favorite price !! :D ). Should be able to tell if you have a cooked battery or a dead cell.
Also, a CTEK battery charger is supposed to be able to recharge a completely dead battery still in the vehicle. Back in the 60's the way you trickle charged a battery was to remove the battery from the vehicle and sit it on a piece of 2x10 wood. Then you removed the caps, made sure the acid level was to the correct level and hooked up the trickle charger. A couple days later when all the cells were bubbling and some liquid had spit onto the top of the battery and the battery was warm to the touch you checked the voltage. Of course you can't do this with an AGM battery. With my 2000 I run the NAPA battery tender. If the car sits a week without being driven it can take three days to achieve full charge according to the tender lights. The battery is less than three years old and is a NAPA 770 CCA battery. |
Thanks for the input.
I just wanted to add that my battery tender appears to be defective in that the light doesn't always go green after a day or so of charging. But if I jiggle the cables or remove them and re-attach them the light will go green! Then when I reconnect the car's cable the battery appears to be fully charged and my Vette will turn right over. So All I'm saying is that that I can't trust the red light on my charger that indicates the battery requires more charging time. Partially defeats the purpose of the little bugger. |
(Post 1590717782)
Interesting to see this thread on the first page. I'm wondering the same thing.
6 weeks ago, it went completely dead after I left it sitting in an airport parking lot for 4 days. Got a jump and drove it for an hour before getting home and it seemed to be fine ever since. But now it just sat for less than 48 hours and went dead again. I didn't leave the lights on, and confirmed the radar detector was unplugged. :crazy2: Yesterday morning, I removed the battery from the car and put it on my battery tender jr. Here I am 24 hours later and it's still got a solid red light. The jr model only puts out 750ma. So I guess it will need another 24 hours at least. O'Reilly's has a battery tender power charger that puts out 5amps but it costs more than a new battery. I guess I will tough it out and charge with what I've got. Then go down and have the battery load tested and maybe check the alternator. edit: got sick of waiting, bought an 8amp Schumacher charger at Walmart for $37. Hooked up for barely 2 hours and it's already done. :) |
