My 3rd engine was a bored over 302, normally run a 4.56 posi.
I've built a few 396 ci small blocks that all turn 7500 rpm. 4.030 X 3.875 stroke
It is very easy to do. Forged rotating assembly, heads that flow over 300 cfm intake, Solid roller cam in the high 240's duration, single plane with 750+ cfm A highly tuned motor can make @ 1.32 foot pounds of TQ per cubic inch. 1.25 is actually closer to street machines with high compression with big heads. But 302 x 1.32 = 398.64 396 x 1.32 = 522.72 122 additional foot pounds will rev. faster in gear by a massive amount. At the drag strip a 302 might break 14.00 seconds and the 396 is good for 11.50 Then just put your 302 emblems on it. |
(Post 1578363023)
imo the whole high nickel block thing is so overrated.
Any GEN I block in decent condition will hold to around 1.2 HP/CID or better...although if you're going to spin it consistently past about 5.8K I would certainly have the block align-honed and pay very close attention to balance. But with the relatively low cost of aftermarket blocks, the uncertainty of GEN I used blocks anymore and expen$ive machine work, it's worth looking at an aftermarket block. This is all before we start talking about high RPM valvetrain dynamics :) Screamer SBCs ain't cheap :thumbs::cheers: |
Originally Posted by gkull
(Post 1578363115)
327 ... never actually known one like it, but ...
+40 over 400 block 3" stroke ---------------------------------------- now have a 377 sitting around ... +30 over 400 block, manley platinum popups, 6" manley I-beams, steel 350 GM crank ... combo was the cat's meow in circle track ... may remain so ... somewhere. ---------------------------------------- At one time, many nascar motors were based on a 400 block w/ 327 crank. |
Didn't Smokey Yunik do some sort of massively oversquare engine thing for his Indy car? I'll have to dig out my old Secrets book and look tonight, but thought I'd see if anyone remembered...
Didnt know he had one be curious to see what you dig up.
Back to the oil thread :leaving: :lol: |
Originally Posted by billla
(Post 1578363725)
http://www.ghostmodels.com/?car;item=606;view=14 |
i remember that engine. my theory on why he did that was to utilize the tendancy for hot gas to rise and also to keep the intake charge cooler. i remember the bundle of snakes headers being where the intake would normally be. I'd hate to try to package that in a street car.
Originally Posted by 7t9l82
(Post 1578360347)
the were great engines. high reving the sound alone is awesome, go for it.
(Post 1578364276)
The idea is ease of the best header sign. Heat keeps velocity up. Ferrari's V-12's have 3 into 1 and 4 megaphone collectors Very highly tuned 10,000 + rpm engines from the 60's The V-8 pipes were adjacent firing cylinders 4 into 1 known as 180 degree headers with two megaphones I work on these motors!:D |
If i did a 302 it would not be a realistic street car. You put big time compression, camming, gears in a motor that small or your wasting your time.
Where i live to much population to do street car. Have to drive it 40 miles to get where you might get away with something. |
(Post 1578363974)
One of our clients bought this car and it was in our shop for work. It has Smokey Yunik as the engine builder. Very radical double over head cam. Injector stacks on the outside and the 8 exhaust pipes on top where the carb and intake usually sit. It is a Ford motor.
Build it billa you know you want to.
rip snortin nasty too no compromises! :smash: |
(Post 1578367163)
I have to admit to being a 350/383 guy pretty much exclusively in GEN I SBCs. I have built a few 396's...but found them to be more work and expense than the 13 CID was worth...just one guy's opinion. |
I've never built a 377 but I'm told they like to turn high rpms and get there quick.
'92-'97 LT1 block, '94-'96 L99 crank = the magical 302 using commonly available(re: cheap and easy to get) factory parts :D You'll have to deal with the reverse flow cooling and it does work better if you keep the factory EFI on it.
Originally Posted by Bugman Jeff
(Post 1578369938)
I would hate to try to spin an opti to 7500 RPM ;) |
(Post 1578370082)
That's an interesting combo for sure :)
Back in the day before the Z 28 Camaro was around we would build a 283 bored out to four inches and built a 301 a fantastic mouse motor a lot of compression 11.5 or more high reving cam matched gearing and real gas that would make a tree hugger quiver.I am showing my age,but back the in the day thats what we did had it in my first Corvette a 59 then Chevrolet got on board with the 302 ahhh the good old school days!:rock:
