Where is the how to on putting new face gauges in?
I remeber seeing it but can't find it. I have some aftermarket gauges that go over the stockers and would like to see the how to. I have everything out already since I put the silver bezel rings I just need to see the rest. Thanks
Originally Posted by Chicago1
(Post 1578356681)
What type of faces did you get...are they just slip on covers or do they have wires/separate power source to them? I hate to say this late...but I hope you used black silicone and not the glue for your bezel rings.:willy: If you did the glue trick...2 things...watch the IPC for discoloration as sometimes the fumes will attach to the black inside portion and fog it over causing it to look white. This is very rare but on occasion has happened. In addition, the glue after 6-8 months becomes hard and brittle. This causes the bezel rings to fall off. There are numerous reports of this. The solution is they went to a "glue gel", while this helped...I still think silicone is a much better solution. It is easier to handle, clean up, and will never get hard.:thumbs: |
I used the glue gell hopefully I won't have those issues but with my luck it will happen lol. I got the ones with the wires and power source. Thanks man I appreciate it
avengershant1@gmail.com |
