growling noise in rear
2006 A6 Z51 6500 miles - when I first back out of the garage it sounds like the tires (or something else) is making a growling noise. The car noise disappears after driving it a few miles. Could the super car tires be responsible for this condition or could the axles be a problem. Never did floor it from a dead stop, but not sure if the dealer or previous owner did, I am coverd by the GMPP till 2013. Any assistance would be appreciated.
BTW - This car drives absolutely great other then the above mentioned problem. |
Originally Posted by redandtan
(Post 1578151488)
Thanks for the advice
Originally Posted by Rick@RKT56
(Post 1578164260)
Does it do this only when turning? If so, it's most likely time to change your diff fluid. I had few in the last month with this exact problem and replacing the diff fluid cured the problem. :thumbs:
Do you use your emergency brake? sometimes the rotors get a surface rust that disappears after a few miles, and can make an awful sound. does the emergency brake cable release all the way? just in case the noise is still there....
jerry |
Thanks
Originally Posted by hydbyj
(Post 1578164553)
jerry |
Just had my diff fluids changed on my 06 with 8000 miles. Made all the difference in the world. No noise!!
(Post 1578164490)
Yes, only when turning. Will take it to the GM dealer for a fluid change - Thanks again.
Growling noise in rear
(Post 1578151488)
2006 A6 Z51 6500 miles - when I first back out of the garage it sounds like the tires (or something else) is making a growling noise. The car noise disappears after driving it a few miles. Any assistance would be appreciated.
(Post 1578201912)
Had the diff drained this morning, additive & new diff (GM) fluid added. Took the car to a local mall and ran it in tight circles to the right and left for about 30 times each. Noise happened for a few turns then disappeared completely. Did end up a little dizzy.Than:thumbs:ks to all for your suggestions, the forum really works well. Thanks. :D
thread mark.... GOT NOISE..
having the same problem on my 07, will be into the dealer this week for the fluid replacement also. Strangely enough my 10 camaro ss is having the same problem and will also get the fluid changed at the same time.
rear diff problems
Originally Posted by fastscout
(Post 1578295765)
(Post 1578296020)
Don't forget to run the vette in tight circles in each direction to spread the new fluid.
WOOOHOOOOOO - Life is good! Headed to dealer today to ask about fluid. |
Originally Posted by GOLD72
(Post 1578172136)
Be sure dealer uses the new DEXRON LS diff fluid which is factory fill for all MY2009 and later vettes.
(Post 1578296950)
The updated GM part # is 88862624 (1.9 qts) and 1032358 if you need the additive.
Originally Posted by gsx1300r
(Post 1578297237)
THANKS Rick - I sure would love you guys to go thru my T56!!!!!!!!!
slow circles or fun ones? lol
(Post 1578297500)
:rock:
Rick see if you can tell me what this rear end noise is then? At the end of the race when I let out of the power I get a gear type of whine from the back of the car. It only happens at the track and only when I let out of the power after the run. I never hear it on the street even when I get on it. This all started when I installed my 315/35-18 Toyor TQ Proxey drag radials. The track does have a bunch of VHT track bite on it so it is pretty sticky. http://i172.photobucket.com/albums/w...GREYCAMERO.jpg |
(Post 1578296950)
That sounds like it's coming from the auto trans not the diff.
Originally Posted by Crowhater
(Post 1578298774)
