93 octane w/10% ethanol or 91 octane ethanol free?
Post asks it all. You opinions and experiences please, as I have access to both here in Vermont.
I have been looking for similar answers. My choice is 94 with 10% or 91 without. I've read all the threads on this and still really don't know which would be better for my car.
My 2011 with LS3 runs better on 91 octane without ethanol (my only other choice is 91/92 with ethanol).
The good: fuel economy is up about 10%, seems to have more power, sulfur smell is gone (I tried all of the top tier gasolines before trying non-ethanol and had a sulfur smell with all of them under hard acceleration). The bad: startup is much louder before NPP valves close (the neighbors even commented on it), there's a bit more cam lope at idle, there's only one gas station selling non-ethanol gas within 15 miles. |
Originally Posted by SERENITY_NOW
(Post 1578136308)
If your car requires 91, but recommends 93, as my Z06 does then I would a say it's a trade off. I'm fortunate, as I can get 94 octane ethanol free gas in my hometown, so I get the maximum performance and the maximum gas mileage. I do pay an additional 10 cents a gallon for the 94 octane ethanol free over 91 octane ethanol free gas. I cut out two nights a year eating at the Golden Corral ($20 total) to pay for the extra cost of the 94 octane. |
Here's the story. Ethanol contains about 80,000 btu's of energy. Gasoline contains 118,000 btu's of energy. Contrary to popular belief, higher octane does not equate to more power or more energy contained in a gallon of gas. Octane inhibits gasolines ability to burn. Higher octane gas is better suited for higher compression engines prone to detonation. The engine in your C6 is designed for 91 octane gas. This is covered in your owners manual. Since ethanol contains less energy per gallon, you have to add more gas to do the same amount of work. Bottom line, if you burn gas with no ethanol, you will see 5-8% better fuel economy (less gas burned to do the same amount of work) and about a 3-5% increase in horsepower. Yes, gas with ethanol is usually cheaper in most parts of the country. This is because ethanol is subsidised by the government and costs less per gallon. This encourages stations to purchase it because they can sell their gas for less. In some states and locals, it is mandated, usually at 10%. You bought a Corvette for it's performance. Use gas without ethanol and you will feel the difference and get better gas mileage. If you put a pencil to it, you will get enough of an increase in fuel economy to pay the difference in the cost. I could go on for an hour about oxygenated fuel (ethanol) and the effect it has on oxygen sensors but will save that for another discussion. Enjoy!
Originally Posted by 1Corvette
(Post 1578137020)
No car running the stock tune has optimum power or economy regardless of whats in the tank.
Oxygenated fuel ( read 10% EtOH ) with a proper tune will run better.
I wish i could get 100 Ethanol! I hate that they put 15% gas in my E85 :lol:
I let the WHP gain speak for it's self :rock: |
Originally Posted by SpinMonster
(Post 1578137733)
The real question would be, are you stock? If so, it doesn't really matter, unlikely you'll see any fuel economy difference, as it's only 10% Ethanol, you'll make the same horsepower.
If you're not stock, and have a tune, run what your tuner tuned your car for or higher only. |
Originally Posted by res0n0xg
(Post 1578143247)
If you're not stock, and have a tune, run what your tuner tuned your car for or higher only. IMHO, a stock tuned car should make more power and get better fuel economy running straight gasoline as long as there's no KR :thumbs: |
I know ethanol is a killer on small engines,boats,atvs anything that sets for a period of time that stuff turns to a powder like substance and clogs everything up.So if your car sets for long periods of time wouldnt be good ideal to run it.Just my 2%
Without a doubt, 91 octane no ethanol.
Producing ethanol from corn is a net energy looser and no one except a BS politician would advocate doing it if they really cared about energy consumption and the economy. |
(Post 1578136308)
So basically by buying the 93 E10 you are paying around 10 - 12 cents per gallon more for 90% of a lower grade fuel that has been cut with 10% of a product that will cut your fuel mileage by 2 -3 miles per gallon. |
Originally Posted by LS3_E85_Corvette
(Post 1578141630)
Originally Posted by AU N EGL
(Post 1578152159)
100% EtOH will help with HP but suck for fuel milage
well yeah! I run E85 on my stock car and MPG when down about 28% however, my 45whp gain thanks me every time I hit the throttle. I still get over 22+mpg on the highway. I didn't get my CORVETTE for gas mileage anyway :cool: The only reason they put 15% gas in E85 so the red-necks wouldn't try to drink it (Moonshine anyone?) :lol: The fastest race cars in the world use E85-100. Technology can handle a higher duty cycle in regards to injectors. It makes more power PERIOD. Let me know if anyone wants to see my Dyno graph on a stock LS3 MN6:cheers: |
Originally Posted by FNBADAZ06
(Post 1578143353)
Actually, it does matter. The factory 91 tune is using a stoic value for fuel that is based on 100 % gas, with no exception to the 10 % ethanol blend. This alters the "real" AFR slightly as well because of this stoic fuel difference. 100% pure gas has more power potential per volume than E10 so given the same injector flow you'll have more power and fuel economy with the 100 % gas product.
Originally Posted by JoesC5
(Post 1578136765)
Depends somewhat on your car. If your owners manual says to run 91 then all you need is 91 and the ethanol free 91 would be even better as each oz of fuel would contain more energy. You would not gain any additional performance using 93 octane and the 10% ethanol would cost you some gas mileage.
Originally Posted by Tobe
(Post 1590499999)
I'm a VTer also. I was told at the Corvette Museum that I should burn 93 in my 2016 Z06. Could you tell me where the station is that you are able to but non-ethanol 94? I'll be paying them a visit before winter storage season.
