86 Corvette Fuel Pump???
Hello fellow Corvette Owners,
I recently bought a 1986 Corvette with the L98. I got it for a reasonable price as the fuel pump wasnt working on the car. The Previous owner had tore it apart and lost the fuel pump assembly, so basically I have a basket case! I talked to someone at Corvette America, and he told me that a fuel pump from a 89 would work on a 86 and that the only issue I may have is a bad fuel indication, since the sending unit is different. So with this advise I bought a fuel pump assembly on ebay, well today it showed up and the plugs are completely different!:toetap: Everything else seems to be fine but until I get the right plug I cant get it to work. Has anyone ever done a conversion like this? If I find the male plug from a 86 could I simply change the plugs? Also on the plug, each wire has a letter above it. They are as followed, the black wire has the letter "A", the purple wire has the letter "B", and the Grey wire has the letter "C". Now my question is whether anyone knows what each wire is for, such as Ground, Power ect. Any help and advice is appreciated and Thanks guys in advance!:thumbs: |
Anyone??? I appreciate any info/advice given!
Thanks |
86 is,
Tan/white= pump power Pink=gauge level input Black=ground According to the FSM I only have the 89's pump electrical, and it's, Tan/white=pump power Black=ground |
Originally Posted by AGENT 86
(Post 1577702450)
86 is,
The units wire colors may be different, but you should be able to trace the units wires and figure out what each wire does.
Alright, I put her together and put fuel in and guess what?? She cranked right up! Thanks alot AGENT 86! I really appreciate the info given! I guess I better go hit the road! Thanks again
:rock: :auto:
