My LS7 roll racer 86 coupe,LME LSX 440,Twin billet 71's and a t56 magnum
First of all I have to thank everyone on the FSC board that is making this build possible! My boy Tim {way2slow},Kevin {junky},Dave {dudeman},adrian {the situation},Nick{pipes} and Brendon {texas heat}
AND BIG THANKS TO DBRODS for the custom turbo kit and chassis fab work!!! Without their help I would be screwed!! Bryan at LME was freaking awesome. Never left me hanging.always answered my questions. Was johnny on the spot threw the whole build. I checked with alot of the other big named engine builders before making a decision on who was gonna build my motor and was brushed to the waist side by some of the other big names. Not by LME!!! Killer customer service!! Rundown on the setup! LME 440 GM LSX with billet main caps {pinned} 4.125 bore 9:5:1 Comp Diamond coated pistons Callies dragon slayer crank Callies Rods Cam Motion turbo grind cam 242/248 .630/.630 115 lsa Morel link lifters All pro series arp hardware Mast Motorsports Ls7 285cc 6 bolt heads Turbo Race ported {420cfm@.650/270cfm@.650} 2.20 titanuim intake valve 1.61 inconel exhaust valve Mast motorsports Ls7 LXR intake aka Cary's intake ported DB RODS custom upper intake elbow Nick williams 102mm tb meziere ewp power bond ud pulley T56 magnum with sprayer mod Mcleod RXT twin disc with miba discs Twin presicion billet 7175's aka 71mm with .96 ar Twin 46mm presicion wastegates Twin 50mm tial wastegates Treadstone 1500hp air to air intercooler parts DBRODS custom turbo kit and mods! Driveshaft shop driveshaft Built 8.8 with 3.27's Should make somewhere in the neighborhood of 750whp@5psi,1000whp@13psi and 1250-1300whp@20psi give or take alittle. HOPE YOU ENJOY!! My 1986 base model 3.8 v6 coupe. Paid $800 and he drove it too me. http://i227.photobucket.com/albums/d...e/DSC03496.jpg http://i227.photobucket.com/albums/d...e/DSC03494.jpg http://i227.photobucket.com/albums/d...e/DSC03493.jpg http://i227.photobucket.com/albums/d...DSC03497-1.jpg http://i227.photobucket.com/albums/d...e/DSC03498.jpg http://i227.photobucket.com/albums/d...e/DSC03499.jpg http://i227.photobucket.com/albums/d...e/DSC03500.jpg |
http://i227.photobucket.com/albums/d...pe/image-4.jpg
http://i227.photobucket.com/albums/d...e/IMG_0765.jpg http://i227.photobucket.com/albums/d...e/IMG_0767.jpg http://i227.photobucket.com/albums/d...e/IMG_0770.jpg http://i227.photobucket.com/albums/d...e/IMG_0794.jpg http://i227.photobucket.com/albums/d...e/IMG_0803.jpg http://i227.photobucket.com/albums/d...e/IMG_0801.jpg http://i227.photobucket.com/albums/d...e/IMG_0822.jpg http://i227.photobucket.com/albums/d...e/IMG_0823.jpg http://i227.photobucket.com/albums/d...e/IMG_0821.jpg |
Sitting at DBRODS
got wolfe mini tubs comp engineering coil over kit upr anti roll bar battle boxes frame connectors fuel cell mounts and sheet metal trunk 6pt roll cage replace rear beam with chrome moly http://i227.photobucket.com/albums/d...e/image-27.jpg http://i227.photobucket.com/albums/d...3/image-68.jpg http://i227.photobucket.com/albums/d...3/image-67.jpg http://i227.photobucket.com/albums/d...03/image-1.jpg http://i227.photobucket.com/albums/d...ED03/image.jpg http://i227.photobucket.com/albums/d...3/image-21.jpg http://i227.photobucket.com/albums/d...03/image-4.jpg |
a few engine pics
http://i227.photobucket.com/albums/d...3/image-25.jpg http://i227.photobucket.com/albums/d...3/image-24.jpg http://i227.photobucket.com/albums/d...3/image-23.jpg http://i227.photobucket.com/albums/d...3/image-22.jpg http://i227.photobucket.com/albums/d...e/image-71.jpg engine dyno numbers 650hp@6800/558tq@5600 http://i227.photobucket.com/albums/d...image-13-1.jpg http://i227.photobucket.com/albums/d...3/image-26.jpg http://i227.photobucket.com/albums/d...3/image-19.jpg http://i227.photobucket.com/albums/d...3/image-20.jpg http://i227.photobucket.com/albums/d...3/image-30.jpg |
T56 MAGNUM with quicktime bell {thanks THE SOURCE}. Mcleod RTX twin disc clutch
http://i227.photobucket.com/albums/d...3/image-27.jpg http://i227.photobucket.com/albums/d...3/image-28.jpg http://i227.photobucket.com/albums/d...3/image-29.jpg The car before it heads back to DBRODS for the turbo kit http://i227.photobucket.com/albums/d...3/image-31.jpg BIG BALLS!!! http://i227.photobucket.com/albums/d...3/image-14.jpg DBRODS CUSTOM TURBO KIT!! http://i227.photobucket.com/albums/d...3/image-52.jpg http://i227.photobucket.com/albums/d...3/image-53.jpg http://i227.photobucket.com/albums/d...3/image-55.jpg http://i227.photobucket.com/albums/d...3/image-54.jpg http://i227.photobucket.com/albums/d...3/image-57.jpg http://i227.photobucket.com/albums/d...3/image-60.jpg http://i227.photobucket.com/albums/d...3/image-61.jpg http://i227.photobucket.com/albums/d...3/image-62.jpg http://i227.photobucket.com/albums/d...3/image-63.jpg |
http://i227.photobucket.com/albums/d...3/image-65.jpg
http://i227.photobucket.com/albums/d...3/image-66.jpg INT http://i227.photobucket.com/albums/d...3/image-64.jpg With the help of some photo shop the car should look like this when its done. minus the tailpipes and cowl hood http://i227.photobucket.com/albums/d...0/DSCF5106.jpg Things are coming to the end!! Once the car is back from DBRODS here in the next few weeks it will be time to put the car back together. Talked to THE DRIVESHAFT SHOP about the driveshaft. They spec'd a 4' aluminun shaft with billet trans yoke,solid joints and strange 1350 style pinion yoke!! Just have to measure and that takes about 3 weeks to get the shaft. Im gonna call up north race cars and order their race disc brake setup for the 8.8 running sn95 10.6 rotor out back. This kit does not push the rear tires out a inch on each side like the 93 cobra or stock 5 lug rear end. The guy sells moser 31 spline axles as well. Then Im gonna probably buy a cobra 31 spline diff for the 8.8 and a diff brace cover. Then order some drag radials... Right now I'm just building it to have fun and roll race. It's the only racing that goes on I'm my area. Later plans are to pull the t56 and run a rossler th400 with the 2.10 first gear and Neal chance convertor. Then have some fun!! Might upgrade the turbos to 76's then. The motors limits is around 2000hp. Will never push it that hard though. Want it to live a long happy life. |
CAR PORN!!!
http://i227.photobucket.com/albums/d...3/image-70.jpg http://i227.photobucket.com/albums/d...3/image-72.jpg http://i227.photobucket.com/albums/d...3/image-71.jpg http://i227.photobucket.com/albums/d...3/image-73.jpg Been working on interior stuff!! trying to knock out the things I cant to make it go together quicker when she gets back. My wife bought me brand new upholstery for my factor seats!! So I stripped the seats down and started recovering them. Thank god my boys in the shop have kickass hog ring tools!! I had to order another driver seat low frame and seat brackets. I guess this car had the typical mustang gangsta lean and someone tried to fix it. Did a crap job. Anywa here are before and after pics http://i227.photobucket.com/albums/d...3/image-74.jpg http://i227.photobucket.com/albums/d...3/image-75.jpg http://i227.photobucket.com/albums/d...3/image-76.jpg |
Awesome work.... Only problem is its a ford in a vette forum so id have to say i wasted a click except for the monster chevy engine?
Why did you spend all this time and money on a shatbox?? You could of bought a cheap c5 vette and modded it. Or are you going for the ultimate sleeper? |
Very cool build. Looks like a lot of time has gone into it.
Originally Posted by RedLs3
(Post 1577670289)
(Post 1577670289)
I sat down a pencil whipped the shxt out of alot of different builds before deciding to do this one. I thought about my priorities. Go fast straight from a roll. Dont need good mpg,1g turns,0-100-0 or worry about taking the wife to dinner in it. I dont need AC or PS for going straight. Those are all things that just cost more money and lead to more problems. Dont misunderstand me!!! Im not hating on vettes!! Everyone has different priorities. Some want to go fast on 20' radials,some want to stick with irs and t56's, some are hell bent on keeping the creature comforts, some want a car that will do everything and I respect that. I want to go fast straight with the most bulletproof car I can. Something I can beat the crap out of with the least amout of issues. Mustangs are light to start,can get crazy 60ft's,the 8.8 will take low 8 sec passes,everything is cheap compared to other cars....its the perfect race car with a inspection sticker. Being a 86 I dont have to worry about emissions just a safety inspection. Or are you going for the ultimate sleeper? http://i227.photobucket.com/albums/d...DSCF3172-1.jpg tell me you wouldnt think in your mind!! I would pound that guy!!! this is what the motor will retire in later in life http://i227.photobucket.com/albums/d...des/img004.jpg |
Awesome!!! Being a Ford guy that owns a Vette I love it!! Reminds me of "Hybrids" car very bad A%%%%.
Originally Posted by 6.0Lcoupe
(Post 1577672266)
I posted it up here because it is a LS7 based setup. I have been on here for sometime and just like all the other car forums the LS7 boys like to see modded LS7's performance and gains etc...
Originally Posted by 4MuscleMachines
(Post 1577675706)
Nice car, I like what your are doing to it, but it really belongs in the "other cars" subforum.
I know how much goes into one of these builds and it's looking great. :cheers: :cheers: |
Originally Posted by joe11204
(Post 1577703507)
Lets cut this guy some slack. He thought well enough to use an LS motor and LS7 head for his powertrain.
indeed very cool
Love this build. Keep up the good work!
(Post 1577703507)
Originally Posted by kageryu311
(Post 1577704262)
:iagree: Exactly. This is a clean build and very very cool.
Originally Posted by JWell
(Post 1577706525)
indeed very cool
Originally Posted by Jeremy@HOB
(Post 1577706779)
Insane!! Looking forward to seeing the finished product!!! :thumbs:
