Changing Licence Plate Bulb..
Can someone tell me how to access the licence plate bulbs so i can change them.. i cant seem to figure it out..
also i was wondering if anyone knew how to access the reverse light bulbs so i can change those too.. thanks guys |
Two screws on each under there. take them out and then shimmy the whole assembly out, change the bulbs and put them back in.
the reverse lights are easy, just get under there and reach in. they just twist off. No jack needed. |
It's a little easier if you take out the tail/brake light closest to the burned out license bulb - you can reach in behind to work it out. If you're really good you can change the bulb that way but you have to do it all one-handed.
Originally Posted by Vivid1
(Post 1577542855)
Just changed mine to LEDs yesterday. Take out the 2 small Torx screws on each light. fish the housing outside the opening, change the bulbs and put it back in with the 2 Torx screws
So was it the fuse or the bulbs or both?
When changing the licence plate bulbs, I am unable to replace the fitting after bulb replacement unless I remove the inner tail lights to use my other hand to hold the holders.
Take out the 2 small Torx screws on each light. fish the housing outside the opening, change the bulbs and put it back in with the 2 Torx screws:iagree:
I was replacing my light bulbs and now they don't turn on as well as the tail lights, any ideas?
Originally Posted by Jazc9
(Post 1581301070)
Take the bulbs out and switch the polarity (reverse the bulb installation). They should work!!
Originally Posted by Peek
(Post 1577542913)
What fuse? Can't seem to find one for license plate light :ack:
Originally Posted by WV Vette
(Post 1577551490)
The reverse lights are actually easier to change.:cheers: |
Originally Posted by nickTsandman
(Post 1581301704)
Originally Posted by casting kid
(Post 1577554884)
(Post 1577542855)
If your installing led lights then yes they have to be installed for polarity but that will not kill your rear parking lights.
This may seem odd, but when I did this I did the two torx screws and got the housing out, but the bulb was like inside the housing thing and there was not a way to get to it? There was the clear housing in front, which was like sealed to the backing (the part that the torx screws go in). It was not like someone had messed with it before. I did see these black 'tab' like things, but moving them seemed to do nothing as they seemed to be holding the wires and not the bulb. I got one of the tabs up a bit and it did move the bulb or anything and to be honest didn't seem to have a purpose. Thoughts?
Very helpful, I just my LEDs and can't wait to install!
