2004 z06 change battery
Hello
I'm not a frequent driver of my car, and my battery is dead. Is it easy to change the battery? On a scale of 1-10, and me being "handy", i'd give myself a 5. or is it just better / easier / safer to have the dealer do it? thanks Mark |
do you really need to ask if it is hard to change a battery? :eek:
it is no harder than putting fuel in the car. :leaving: |
I had a C4 and changing the battery was a little tricky. The C5 battery is simple, just take it out.
Note: the battery will go dead from lack of use because the car has a continuous drain on it. That does not mean the battery is bad, it may just need to be charged. |
Originally Posted by imavettegirl
(Post 1577524055)
Originally Posted by markymarq
(Post 1577523762)
Hello
(Post 1577524055)
Just remember negative off first and on last.
Even a caveman can do it.:thumbs::thumbs: Oh, by the way the black one is the negative.:thumbs: |
7 year old battery, its time to change."You Can Do It"!!!!!!
Not hard at all.
But there is one small catch, be sure to write down the "unlock" code for your radio, if you have that enabled. My battery went dead, and after recharging. I had to unlock the radio. Good thing I wrote that down in the owners manual, back in 2002 when I bought the car. Cause I damn sure couldn't remember it, 7 years later. |
Originally Posted by 2K3Z06
(Post 1577535089)
Not hard at all.
(Post 1577523762)
Hello
I'm not a frequent driver of my car, and my battery is dead. Is it easy to change the battery? On a scale of 1-10, and me being "handy", i'd give myself a 5. or is it just better / easier / safer to have the dealer do it? thanks Mark Go with an Optima - so no battery acid leaks. |
Real easy. Just swapped mine out to an Optima red top.
if the battery died in the vehicle the code for the radio is a mute point.
you either know it or you don't. |
Originally Posted by NatB
(Post 1577538344)
Do yourself a favor and just have a store install the battery.
(Post 1577540629)
if the battery died in the vehicle the code for the radio is a moot point.
Make sure that the battery is secured tightly. You will think your whole suspension is coming apart if its not secured in there and flopping around.
Don't ask me how I know... :lol: Toque |
(Post 1577540629)
my factory battery finally died...replaced mine last night. took me all of 7 - 8 minutes...use a 10 and 13mm socket. good luck:cheers:
DIY...beyond real easy.
I give this a 1 on a scale of 1-10
