TCS No Comm .....
... Tech 2 says the same.
All the other codes have the H - are they still relevant? Its an 03 Z with about 22k miles The battery was completely dead this spring(i didn't disconnect it thinking i may have to move it on occasion) Now has a new battery. Grounds look clean and dry... Any thoughts? Okay here are the other Codes; 10 PCM:P 1571 HC 28 TCS:No Comm 40 BCM:B 0503 H,B 0508 H,B 2588 H,B2592 H 58 SDM:U 1040 HC A0-LDCM:B 2282 H,B 2284 H,U 1064 H A1-RDCM:B 2283 H,B 2285 H,U 1064 H A6-SCM:B 0851 H B0-RFA:U 1255 H Thanks once again for any help men! Dom NOT SURE WHY THE PUKING GUYS ARE THERE-I DIDN"T INSERT THEM! |
Originally Posted by ChopperLoco
(Post 1577385276)
All the other codes have the H - are they still relevant? |
Clear ALL the DTCs and see what comes back... Coud be left over DTCs from the battery reconnect. Post all the DTCs that come back after clearing.
BC |
I'd clear the codes and take it it for a ride and see what comes back and then go from there.
A dead battery causes all kinds of issues, that are typically cured by a new one. |
"H" means it is a HISTORY code or old code
Originally Posted by lucky131969
(Post 1577386540)
If you don't post them, how can that question be answered? :toetap:
Originally Posted by Bill Curlee
(Post 1577388848)
BC |
TTT for help with the codes-First post!
Thanks Dom |
(Post 1577406414)
Thanks Dom You need to check your battery connections for corrosion tightness and also check the other end of the battery negative cable where it is attached to ground to make sure it is in good condition. Bill |
(Post 1577395156)
LOL-I guess i was thinking if they were history it was not a problem.
(Post 1577407852)
Did you do what the others said to do? Clear codes and drive the car? Are these the codes you have after doing that? If so they indicate you still have a voltage problem of some sort since you have door voltage codes showing.
You need to check your battery connections for corrosion tightness and also check the other end of the battery negative cable where it is attached to ground to make sure it is in good condition. Bill How does one clear the codes? Will check negative etc. Dom |
(Post 1577408265)
Thanks Bill
I miss-understood "clearing the codes",and have now done so. Went for a drive-this is what i have: 10 PCM - P 1571 HC TCS - No Comm 58SDM - U1040 HC Any more thoughts? Dom |
(Post 1577423721)
Thanks once again!
I miss-understood "clearing the codes",and have now done so. Went for a drive-this is what i have: 10 PCM - P 1571 HC TCS - No Comm 58SDM - U1040 HC Any more thoughts? Dom BC |
(Post 1577424628)
Check the fuses and grounds to the EBTCM first.. Report back
BC Thanks |
Chassis Ground G-101 and 104/108
http://img.photobucket.com/albums/v4...dlocations.jpg 101 http://img.photobucket.com/albums/v4...Z06ground2.jpg 104/108 http://img.photobucket.com/albums/v4...ndG-104002.jpg |
[QUOTE=Bill Curlee;1577442047]Chassis Ground G-101 and 104/108
Thanks for the help again Bill-checked these grounds visually and with the test light-all good-not seeing any bad fuses either! Dom |
Have you physically checked each EBTCM fuse with a METER and varfied that there is the correct voltage on each fuse??
http://img.photobucket.com/albums/v4...r-Gnd-Stop.jpg http://img.photobucket.com/albums/v4...Schematic1.gif Make sure that you read the fuses powered by RUN in ON & Start with the ignition ON and make sure that those fuses read full battery voltage! BC |
I know this is an old post but it was very helpful my TC and ABS lights started coming on, but once and a while they didn't.
I did think it was the Traction control switch, but I was still checking things to make sure. What I found was the ground next to the battery under the battery heat shield shown above by Bill Curlee in the second pic was super loose. Thank you Mr Curlee you saved me quite a few hours of going crazy looking and testing. |
Okay,voltage at the fuses is consistant with the battery-fuses are all good,checked all grounds and still no luck!
EBCM done? Dom |
