Replaced my relay and I am now good to go!!!
Originally Posted by Bill Curlee
(Post 1577343267)
EXCELLENT POST and guidance! This will save a LOT of people a LOT of CASH.
Good to hear and thanks to all who followed this. Wouldn't be a good write up if no one did the repair.
I have a 98 that just started to throw these same codes intermittently , others have reported. I pulled mine out today, is there still not a fix for these years?
Half that can be removed from the car. http://i46.tinypic.com/1z1tmdl.jpg http://i46.tinypic.com/bfkrpw.jpg The other half still attached in the car. http://i50.tinypic.com/2qi9t1k.jpg |
Code 1274
Well I have an 01 c5 with 50k miles always garaged never in rain. I live in california., I would get the 1214 code and abs, Traction control message when I would start the car, If I started it a second time the message would go away. It would not happen every time. So I found this thread and removed the EBCM and found a couple of solder joints bad, I resoldered the bad connections, When I installed it for a test the 1214 was gone but the code 1274 came up with the abs, traction control message, I can't clear the 1274, and the message is on constant. I have checked and cleaned the grounds, and checked the elect. connections.
What did I do wrong ? |
Originally Posted by vbk1
(Post 1581961240)
What did I do wrong ? Document ID# 670689 2001 Chevrolet/Geo Corvette -------------------------------------------------------------------------------- DTC C1261-C1274 Circuit Description The system relay is energized when the ignition is ON. The system relay supplies voltage to the valve solenoids and the pump motor. This voltage is referred to as the system voltage. The electronic brake control module (EBCM) microprocessor activates the valve solenoids by grounding the control circuit. Conditions for Running the DTC The system voltage is greater than 8 volts. The ignition voltage is greater than 9 volts. Conditions for Setting the DTC The commanded state of the driver and the actual state of the control circuit do not match for 0.03 seconds. Action Taken When the DTC Sets If equipped, the following actions occur: The EBCM disables the ABS/TCS/VSES for the duration of the ignition cycle. The DRP does not function optimally. The ABS indicator turns ON. The Traction Control and Active Handling indicator turns ON. The DIC displays the following messages: Service ABS Service Traction System Service Active Handling Conditions for Clearing the DTC The condition for the DTC is no longer present and the DTC is cleared with a scan tool. The EBCM automatically clears the history DTC when a current DTC is not detected in 100 consecutive drive cycles. Diagnostic Aids The solenoid valve circuit is internal to the EBCM. The solenoid valve circuit is not diagnosable external to the EBCM. The DTC sets when there is a malfunction in the solenoid circuit internal to the EBCM. Test Description The number below refers to the step number on the diagnostic table. Determines whether the DTC is current. Step Action Yes No Schematic Reference: ABS Schematics 1 Did you perform the ABS Diagnostic System Check? Go to Step 2 Go to Diagnostic System Check - ABS 2 Install a scan tool. Turn ON the ignition, with the engine OFF. Use the scan tool in order to clear the DTCs. With the scan tool, perform the Automated Test. Does the DTC reset as a current DTC? Go to Step 3 Go to Testing for Intermittent and Poor Connections in Wiring Systems 3 Replace the EBCM. Refer to Electronic Brake Control Module (EBCM) Replacement . Did you complete the repair? Go to Step 4 -- 4 Use the scan tool in order to clear the DTCs. With the scan tool, perform the Automated Test. Does the DTC reset? Go to Step 2 System OK -------------------------------------------------------------------------------- Document ID# 670689 2001 Chevrolet/Geo Corvette |
Ebcm
Well I pulled the EBCM and looked again, All soder connections look good, I took an ohm meter and checked the power and grounds from the terminals to the board and they checked good, In reading this thread the relay may need to be replaced, does anyone have a sceamatic for the relay so I can check to see if there is an open or a solid connection that should not be there, also I don't have a scan tool. I pulled the codes from the dash.
Thanks, |
Originally Posted by Qwik01
(Post 1577916152)
What kind of solder is everyone using? I haven't had to fix the EBCM yet, but I have fixed the HVAC display. Silver solder melts at a higher temp but makes a beautiful solder joint. I got the solder at Radio Shack but it would be cheaper at digikey.com or mouser.com. Good luck on the repair. |
OK, I checked all solder joints and no pin damage, it still has the code 1274 and will not clear, I guess the next step would be to replace the relay. or replace the EBCM.
Before you make your move,,, get a meter and check the relay contact resistance. Heres a post for you to check out . It shows you what a bad relay contact looks like.. Look at post 77 to the end:
http://forums.corvetteforum.com/c5-t...post1581990753 |
Note sometimes the resistance of the relay goes up and can't be measured properly. The pin that holds the high current contactor is normally a rivet and the heating/cooling causes the rivet to change resistance and the problem may be in the rivet not the contacts themselves. My advice would to replace the relay anyway.
Just to clarify, only 97-00 cars with active handling have an ebcm, correct?
Thanks for the help, I measured the resistance with the relay installed,
between a1 and a2 = 175.6 ohms between 11 and 12 = .2 ohms between 11 and 14 = 2.64 I am not sure what the values should be . Thanks. |
Originally Posted by I dream of vettes
(Post 1582001894)
(Post 1582001894)
Originally Posted by jimcork1
(Post 1582002598)
No all years have them, but the 97 - 01 cars use a different part and so far no solution has been found to repair them and GM doesn't support the car by having this part available.
Preface by stating my parts manual only goes up to 2002...... 97-98(early) are the same....and are rear mounted. 98(late)-2000 are the same - front mounted 2001 and 2002 are different part numbers - front mounted |
(Post 1582002598)
http://forums.corvetteforum.com/c5-g...abs-units.html |
Originally Posted by Chilliwack vettes
(Post 1582003269)
This was posted a few days ago regarding a fix for the '97 & up ones.
I pulled the relay out, took it apart and put 12v to it and it worked. the points looked good, so maybe I have a different problem. the relay I have is a T72M5D155-12-12. is the
T7NS5d1-12 the same? Thanks |
Try removing all fuses related to the ebcm all at once....clean the leads real well and put them back in.
