05 Hood Struts won't stay open
I went to check my fluids yesterday and my hood struts won't stay in the upright position to keep the hood open. Has anyone ever had that happen with no incident? Is this covered under warranty or do I have to replace? Any advise is appreciated. Thanks,Dean.:smash:
Originally Posted by Dean Prevolos
(Post 1577136194)
At each end of the strut, there is a band clip that has to be at least partially removed by prying with a small flat blade screwdriver. Tug on the strut end at the same time. The strut attaches to a small ball on the hood bracket and the band clip retains the strut to the ball at each end. The new strut just snaps in place. I used a little lube spray at each end to ease the new strut snapping back in place. It is really a simple R/R. |
I had to replace both of mine last year on a 2005. I noticed that the hood wouldn't stay up with a slight breeze.
Have a helper with you to hold the hood steady and take the pressure off the strut while you change each one. It only takes about 2 minutes to change each one. So simple a cave man could do it!! Andy |
just replaced my hood and rear hatch struts. Very easy. Agree that it is much easier with two people.
Do you have an extended warranty? If not, you gotta eat it.
Thanks for all the responses. I will take another look at them and take Gold 72 advise to buy one and take the educated guess when I change it out. Hopefully it is just one of them.
And to NYC6, I do not have an extended warranty. Thanks. |
I would suggest buying two. If I recall correctly, they were not that expensive.
Considering it is a 2005 model, both are probably worn out. I had to replace both on my 2005 last year. Andy |
Just buy both, about 19 bucks each at Amazon.
Just replace them. They're next to nothing on amazon.
These are the ones I replaced my OEM ones with. Changed them over a year ago, no issues. |
:iagree: Replace them both, because if one is weak, the other is not long behind.
I have a 2006, and I've replaced the hood struts, and hatch struts within the past few years. Amazon is the place to buy them for a great price. |
Originally Posted by Strid56
(Post 1591868439)
Originally Posted by schpenxel
(Post 1591868653)
These are the ones I replaced my OEM ones with. Changed them over a year ago, no issues. Amazon.com: StrongArm 6330 Chevrolet Corvette 2005-06 Hood Lift Support, Pack of 1: Automotive |
(Post 1577136194)
https://cimg7.ibsrv.net/gimg/www.cor...7794b767ae.jpg
I used a sliding door bar. https://cimg8.ibsrv.net/gimg/www.cor...5344ba7938.jpg front pivot point https://cimg9.ibsrv.net/gimg/www.cor...08640bedaf.jpg rear pivot point I second the Strongarms |
Over time, these get tired out with any type of car.
