Can engine run with timing 180 off?
My small block was running great. So I decided to do a cam change and tear it apart. I wanted to check the timing marks from the previous owners build. So I did the following.
1. Marked #1 plug on dist. base and removed cap. 2. Rotated crank until rotor pointed at #1 (confirmed compression) then put the mark on the balancer at zero on the timing tab. 3. Removed the timing chain cover. Now at this point I was expecting to find the crank dot at 12 o'clock and the cam dot at 6 o'clock. That did not happen. The crank was at 12 o'clock AND them cam sprocket was also at 12 o'clock. When I line them up at 12 and 6 the rotor points at #6. Is this possible? I am confused |
I fired mine up 180 degrees off, and it was a scary violent experience. Although it ran, it sputtered, chugged, and flamed out the carb.
It was nowhere near driveable though. |
What am I missing here?
I just don't understand because the cam sprocket is keyed to only go one way. Here is a better question. When the dots are at 12 and 6, where does the rotor point? mine points at #6 plug |
The dots just need to line up at 12 and 6 or 12 and 12 ,don't worry about the timing tab at this point.
Originally Posted by johnt365
(Post 1577033687)
I just don't understand because the cam sprocket is keyed to only go one way. Here is a better question. When the dots are at 12 and 6, where does the rotor point? mine points at #6 plug edit-removed part of my post, it was confusing and I said 180 when I should have said 360 and I misread what the OP was after. Mike Ward covered it. |
(Post 1577033499)
(Post 1577034089)
:lol: Right, at #1 the crank is 12 and cam is 12.
I thought that at crank 12 and cam 6 the motor should be at TDC and rotor at #1 Mine is #1 compression (TDC) and both dots at 12 o clock. Is something wrong |
Okay, just so I can understand.
Dot to dot is TDC but NOT the compression stroke. To time the engine I need to rotate it 180 so that its crank 12 o'clock and cam 12 o'clock and that will be TDC on the compression stroke. I was about to be "one of those people" |
Originally Posted by stingr4y
(Post 1577033636)
It was nowhere near driveable though. It no where resembles an engine running! My wife ran for the hills, the neighbors baby started crying, etc...:D |
(Post 1577034210)
Dot to dot is TDC but NOT the compression stroke. To time the engine I need to rotate it 180 so that its crank 12 o'clock and cam 12 o'clock and that will be TDC on the compression stroke. |
just about the time I think I know something... Bam! something like this happens.
Thanks fellas ! |
You can make sure by holding your finger over the number one spark plug hole while you turn the crankshaft over.
