Never had any problems with the windows (unlike the door locks) but, yes, I have rattles when the windows are down. Its still rattle free when they're up.
The driver's side rattles just a little when shut in the down position. The passenger side - not at all. It's a Chevy. The C6 quality, at least as far as squeeks and rattles, is much better.
Here is a possible rattle fix. My '99 C5 convertible had a nasty rattle with windows down, driver’s side much worse than passenger. Fix was about an hour per door, most time required to remove door panels. Drivers side issue was the rubber sleeve on the post at the base of window regulator (behind stereo speaker). Passenger side fix was easier, window regulator nut (behind reflector) had loosened -- added Loctite and tightened nut, problem(s) solved!!!
no rattle on mine 04 z06
Originally Posted by AZ99FRC
(Post 1576970534)
That's why I'm always yelling at my wife…'don't slam the damn door!'
My 2001 Convertible driver side window does rattle when I close it. Not a bad rattle, but noticable. When I park it in warm weather I lower the window about 2 inches. No rattle when it is not lowered. Does not bother me since I never slam the door. Not sure if the passenger side does it too, but except it will do it also.
I wouldnt say mine rattles, but my drivers side door does sound hollow (like a bang) but my pass side sounds like a clunk, niether sounds broken.
No rattles at all in my 98. The only noise I have in the car at all is a clip or something on the passenger side seatbelt that makes noise when I am going 50+ with the windows down.
(Post 1576970534)
window on the drivers side rattles when down, no rattles when up though. pass side no problems at all. one day going to take off the door panels to replace the stock speakers, going to see about fixing it then. :thumbs:
Originally Posted by Oldvetter
(Post 1576981172)
Not only does my 1998 Coupe rattle when you close the door with thw glass down, BUT it also rattles with the window all the way down while driving. You only have to touch the up button to make it stop rattling, you can't even see the glass after this.
Mine don't make noise, but I'm sure to have the windows up or most of the way down when the door closes....kind of like a pet peeve of mine to avoid having loose window regulator mechanisms. I never drive with the window only a little way down either, due to it having all that upper end weight shaking around and yanking on the mechanism inside the door, loosening things up. I either only crack them, or I go over 50% of the way down.
Yes...I'm compulsive bout avoiding rattling window regulator mechanisms. My C4 sounded like hell when you closed the door with the window partially or all the way down...sounded like junk. Never again...lol. |
