whats a good range for the air fuel ratio
What is an acceptable range for the air fuel ratio?
Originally Posted by jtearp
(Post 1576946182)
Frans96ss - yes I mean at WOT. Stock bottom end with the following:
cam - 248/260 .658/.660 114 ported heads fast 102 intake ported throttle body 1 7/8 long tubes with high flow cats |
i think its suppose to be 12.1 WOT and 14.9 Idle
generally at wot a good a/f is 12.9-13.1. From what I seen, the LS7 seems to like 12.5-12.6
12.2-12.8. Some cars like it richer, some leaner. Mine is dialed in around 12.6.
(Post 1576946462)
Also depends on where you are measuring the a/f at. If measuring from a w/b 02 bung in the header, I always shoot for ~12.5ish. I do favor conservatism in my tuning though.
