Will Acrylic Enamel spray paint hold up on my brake calipers?
I've been searching paint shops online to find someone who can mix a Mag Red I into a rattle can or something really close to Mag Red. I found a place but they are not sure if it would handle the heat from the calipers. They can mix Acrylic Enamel into a spray can that can handle up to maybe 400 degrees.
I've already painted my calipers with the black caliper paint that can handle 900 degrees but now I think I want to color match the calipers with the car. Would the black caliper paint help with the heat if I was to spray the acrylic over them? I don't want my car looking like garbage so any advice would be great right now. How hot will calipers get during the summer months? I don't track or drag my car. Thanks |
checkers auto parts sells duplicolor caliper paint. it is red and will be real close to your mag red color.....
i doubt it. normal acrylic enamel isnt made to withstand high heat. use caliper paint or engine enamel.
I use VHT in a rattle can from AutoZone.
Originally Posted by SaberD
(Post 1576695192)
We carry really heavy duty caliper paint that comes in red on our site. Check it out:thumbs:
So, what IS caliper and engine paint? Enamel, acrylic, or laquer?
I painted my calipers with plain old Rustoleum paint from a can....it has lasted fine for over 4 years......so yes, I think any decent spray paint will be fine.
Originally Posted by corvettemods1
(Post 1576695244)
Originally Posted by jrose7004
(Post 1576695202)
So far it's looking like I'm stuck on black for now. |
do not go yellow!!! :ack::U
Originally Posted by jrprich
(Post 1576695423)
You will be fine with a regularly driven car. Under normal driving conditions, the calipers barely get hot. Feel them the next time you finish a drive and park the car. If you do canyon carving or agressive mountain driving in the western part of the state, they will get hot enough to possibly blister normal paint.
i painted my calipers about 2 years ago with the duplicolor caliper paint, they still look as good as they did when they were first done....
I think a good spray paint will work fine for normal driving. However, have you considered powdercoating - Corvette-Pilot here on the forum does an excellent job and can probably do mag red for you.
:iagree: The outside of the calipers doesn't get very hot.
I also used Rustoleum paint. I did a pad change this week and was going to repaint them but I didn't bother as they are still OK. |
I used the Duplicolor brush on about 4 years ago and they still look great
Originally Posted by vettesplus
(Post 1576697042)
Secret is cleaning the calipers well and using several coats of paint. Did this when replcing pads so I could paint the caliper completely. Used red Duplicolor for about $15. |
3 Attachment(s)
Here is the front caliper from a set that I am working on. I used the red Duplicolor in a spray can. To mask off the areas I used a dime sized cutout of masking tape for the brake line inlet and found a cheese grating wheel that was the perfect size for the piston cylinders. Very happy with the results!
I am also thinking of doing this. I repainted my calipers with Ford Engine Red which matches the Torch Red pretty good but not exact. It's a bit more dull and I am being a bit anal. I was wondering if I could use duplicor since they make a Torch Red in the can that is an exact match.
Originally Posted by Neck Breaker
(Post 1576694951)
Originally Posted by Gitusum
(Post 1576695721)
The Big Dog |
