Navigation System for sale
I have recently bought a new sound system for my vehicle. Anyone interested let me know. Selling price would be 575.00. Open to any reasonable offers.
Thank you The Rooster! |
Originally Posted by Dirty C6R
(Post 1576497277)
Originally Posted by Cdn Z06 Mike
(Post 1576497386)
Hey Rooster I'll check with a guy who I knew was looking and get back to you.
(Post 1576497277)
Originally Posted by 3Xvette
(Post 1576508513)
What year Vette is it out of ?
Thaks for the respond A.K.A The Rooster! |
Mine is a 2005 and i think 2009 and up have Blue Tooth, so im not really sure if this is plug and play or if it is even possible on mine.
Maybe someone might chime in to see what is involved. Steve, |
(Post 1576510209)
Maybe someone might chime in to see what is involved. Steve, A.K.A. The Rooster! |
Where are you located ?
(Post 1576513449)
Nav
To try help you sell this unit , Here is how to install it ,
http://www.skyhighphotos.net/CorvetteNAV.htm The nav for 05 to 08 are pretty well the same , They will work , But here is the catch , The 05 and 06 ''Do Not Have Steering Wheel Controls '' So The Best unit is the 07 to 08. The 09 is difference The number on the top should be '15791220 . takes about 1 hr to install . But unit will 'LOCK UP ' The sec you cycle the key to the run position , If you want to see if it works put it in the acc position . Go to you Gm dealer , it's a good idea to get a 'BILL OF SALE ' for unit with serial number , It takes about 5 min to 'ONLOCK 'unit . If you car does not have Onstar to get the VOICE Commands to work you will have to replace the A pillar trim piece , with one with the Mic in it . Nav will only work with cars with BOSE Stereo I purchased one unit from Cdn Z06 Mike, Thanks Mike:canadaflag: |
Originally Posted by ZR-1 1991
(Post 1576517996)
http://www.skyhighphotos.net/CorvetteNAV.htm The nav for 05 to 08 are pretty well the same , They will work , But here is the catch , The 05 and 06 ''Do Not Have Steering Wheel Controls '' So The Best unit is the 07 to 08. The 09 is difference The number on the top should be '15791220 . takes about 1 hr to install . But unit will 'LOCK UP ' The sec you cycle the key to the run position , If you want to see if it works put it in the acc position . Go to you Gm dealer , it's a good idea to get a 'BILL OF SALE ' for unit with serial number , It takes about 5 min to 'ONLOCK 'unit . If you car does not have Onstar to get the VOICE Commands to work you will have to replace the A pillar trim piece , with one with the Mic in it . Nav will only work with cars with BOSE Ster I purchased one unit from Cdn Z06 Mike, Thanks Mike:canadaflag: Thanks. A.K.A The Rooster! |
(Post 1576517996)
http://www.skyhighphotos.net/CorvetteNAV.htm The nav for 05 to 08 are pretty well the same , They will work , But here is the catch , The 05 and 06 ''Do Not Have Steering Wheel Controls '' So The Best unit is the 07 to 08. The 09 is difference The number on the top should be '15791220 . takes about 1 hr to install . But unit will 'LOCK UP ' The sec you cycle the key to the run position , If you want to see if it works put it in the acc position . Go to you Gm dealer , it's a good idea to get a 'BILL OF SALE ' for unit with serial number , It takes about 5 min to 'ONLOCK 'unit . If you car does not have Onstar to get the VOICE Commands to work you will have to replace the A pillar trim piece , with one with the Mic in it . Nav will only work with cars with BOSE Stereo I purchased one unit from Cdn Z06 Mike, Thanks Mike:canadaflag: thinking about removing the GM nav system from my car & going back to the stock radio/CD unit ,or maybe aftermarket this spring.I'll just reverse the instructions.Spent the morning at Mike's just shootin the breeze ,having coffee & comparing Vettes. |
Unit is sold. :D
(Post 1576529490)
Unit is sold. :D
