Power seats and telescopic stopped working please help
Like the topic said I took the car to get washed when I got it back they stopped working ! I think I tried everything checked all fuses including the ones in the sub box checked connections under seat, tried soft reset ,unhooked the battery for 2 hours !!! Please anybody with ideas respond I have an appointment tomorrow at the dealership I'd rather not go ......one more thing when I press the switches I hear a click I guess that's the relay I'm stumped ..thanks
Originally Posted by nunii
(Post 1576429182)
really strange problem. nunii is my cousin. weve tried everything including testing every fuse in the car and unplugging the harness under the seat. someone has to have had this problem before. any takers??? |
Is it both seats that don't work? Maybe check the wire harness under the passenger side. Can't hurt to try. Other than that I have no ideas. Good luck with it.
Originally Posted by EVRose
(Post 1576429588)
(Post 1576429182)
Yep tried wiggling it too no go
I fixed my telescopic and dirver side power seat. I found that two wires under the seat sheared off. Most likely from the seat being so low and me getting in and out of the car, causing the wire to eventually break. You can only bend a wire back and forth so many times before the copper yields and brakes.
re-attached the wires to the connector and everything works as before! :cheers: http://i120.photobucket.com/albums/o...6/IMG_1365.jpg http://i120.photobucket.com/albums/o...IMG_1366-2.jpg |
I have this exact same issue! Did you uncover the problem?
Yes, it you re-read my post, you will see that the center connector got separated from the wires. I re-attached the wire to the connector and plugged in the connector.. :flag:
I hate user names – were you able to fix what’s going on with your Corvette? Please send me a PM if you’re still having issues.
Thanks, Laura GM Customer Service |
