-   C3 Tech/Performance (https://www.corvetteforum.com/forums/c3-tech-performance-3/)
-   -   What is the kick down passing gear switch called? (https://www.corvetteforum.com/forums/c3-tech-performance/274510-what-is-the-kick-down-passing-gear-switch-called.html)
69er 04-08-2002 06:43 AM
Don't have a passing gear.I figure maybe the switch is bad.
Don't know what the switch is actually called on a TH400 unless it's just called the kickdown switch.
I only looked in one catalog so far and can't find it.
ddecart 04-08-2002 08:30 AM
Re: What is the kick down passing gear switch called? (69er)
I always thought it was just the kickdown. Can't recall or even make up a different name for it.
Dave
TravMsns 04-08-2002 09:09 AM
Re: What is the kick down passing gear switch called? (ddecart)
throttle kickdown
DaBo 04-08-2002 11:46 AM
Re: What is the kick down passing gear switch called? (TravMsns)
kickdown switch. :yesnod:
Tom73 04-08-2002 01:35 PM
A Detent Switch maybe? At least that is what it is on the '73.
tom...
Cookwithvette 04-08-2002 02:02 PM
Re: What is the kick down passing gear switch called? (Tom73)
Tom got it Detent Switch. :yesnod:
69er 04-08-2002 04:35 PM
Re: What is the kick down passing gear switch called? (Cookwithvette)
Thanks for the replies guys.
It is a Detent Switch.
I see one in rik's but for 70-77.
It seems a '68-'69 isn't listed.
Any ideas?
Alwyn678 04-08-2002 04:43 PM
Are u sure it is hooked up??? when I put in my new tourque converter mine was actually unhooked
69er 04-08-2002 05:12 PM
Re: What is the kick down passing gear switch called? (Alwyn678)
Good point.
I didn't install my TC. :cheers:
ZD75blue 04-08-2002 05:16 PM
The moment that a small block feels like a bigblock... :(
69er 04-08-2002 05:42 PM
Re: What is the kick down passing gear switch called? (ZD75blue)
Sort of :lol:
Thinking back never had a problem after performance trans rebuild and 2400TC.
This problem started after I went from a Holley Avenger carb to my Lars rebuilt qjet which runs great.
Linkage?
[Modified by 69er, 4:02 PM 4/8/2002]
Matt Gruber 04-08-2002 07:06 PM
i call it a lever switch. Got 6 out of an old VCR.
radioshack sell them for $1.99
Put another one on the console for "paddle" shiftng.
69er 04-08-2002 09:55 PM
Re: What is the kick down passing gear switch called? (drives61)
Interesting!
