Anyone Jet-Hot coat BB exh. manifolds?
I know heat is an issue with some of the BB's, so wondered if anyone has had their stock BB exh. manifolds Jet-Hot coated in the flat cast iron gray color. Thinking this keeps the stock look, may cut down on heat, and help exhaust flow.
Originally Posted by DRC
(Post 1576163492)
(Post 1576163492)
I have Jet Hot coated longtubes on one of my car's and still look like new. Jet Hot does warn about running very lean carb A/F ratio's that can cause exhaust temperature's to soar though. Don't think BB's run any hotter than most engine's, just create larger quantity's of heat. Maybe scan your manifold's with a IR thermal gun and contact Jet Hot. Coating the manifold's may help underhood temperature's a bit, but you still have the raw steel exhaust pipe's running up to them.
As I rebuilt my car, I was looking for a way to coat the original manifolds and came upon something called "aluminizing". Cost me $100.00 bucks total for both sides. That was five years ago and they look just like they did when I put them on. They're white with a mat finish. I've spilled a little oil, etc. on them and it burns off with no affect on the finish. Its another option. Had it done at a metal fabrication, sand blasting shop.
