how would one remove the mild to wild switch?
i have a z06 b&b fusion catback now and think that im going to be removing it shortly. how would i go about removing the mild to wild setup and all that. i have 2 fobs that wirelessly open the valve open and closed. the car came with the setup on it but once i sell it, i want to sell it together. from what i have seen, theres some wiring, a little brain, and somehow ties all this in together for the setup. i searched and couldnt find a specific m2w thread that matches my fobs. i found the ones with the pontiac looking fob (big button, little button, round oval fob) but mine is black, square and has 2 buttons, one red, one green. i dont want to remove only part of it, just to find out that the guy who buys it didnt get everything he needed off my car... thanks!
"one" should probably go to the manufacturers page and follow the instructions.
just go to the DIY section on "how to install" and just follow the directions in revers order. :thumbs:
Originally Posted by captej
(Post 1576024014)
sav, thanks, ill look into it... |
The transmitter plugs into the EXH fuse slot, located under your passenger's side foorwell. Just pull the sucker & replace it with the (10A?) fuse. Simple as that.
IF you're not sure about which fuse slot, look for a device with a smallish wire antenna on the fuse block, that'd be it. Your owner's manual will help to ID the proper fuse location if you've any doubt(s). :thumbs: |
so essentially the kit is just a radio(transmitter thats in the fuse box), a pair of fobs, and thats it? everything else is from the exhaust and the valve setup from gm?
Originally Posted by Landru
(Post 1576024318)
Originally Posted by 1badvr4
(Post 1576024376)
(kinda disappointing, huh. :lol:) |
(Post 1576024376)
(Post 1576024376)
:cheers: |
Don't forget to disconnect the ground wire also:D
Here's a link to the install instructions from southerncarparts.com with pictures. http://www.southerncarparts.com/Inst/m2w.pdf
You should be able to figure it out from there. It's very straight forward. Good luck. Shouldn't have any problems selling this set up. |
