15x6 JJ code wheel
Is this a Corvette wheel?? Can anyone ID??
Dave |
Dave, the JJ you've posted doesn't show up on any list I've found as a "Wheel Code", it does show up as a "Rim Code" on a lot of different rally wheels.
http://chevellestuff.net/qd/rally_wheels.htm Look on the wheel for a Wheel Code next to the valve stem hole. It should correspond to one of the codes in the left column here... XA 14X5 B-3 1/2 67 Chevy II with drum brakes DA 14X5 B-3 7/8 67 Chevy II RALLY with disc brakes DG 14X6 67 Camaro & Chevelle with dics brakes XB 14X6 B-4 3/8 67 Chevelle SS, 68-69 Chevelle with F-70 Tires, 70 Chevelle XN 14X6 B-3 3/4 68-69 Camaro & Nova with drum brakes. Different shaped outer AE 14X6 B-4 3/8 70 Chevelle Station Wagon XG 14X6 B-3 7/8 68-69 Camaro with dics brakes, 68-70 Chevy II/ Nova with disc brakes, 69-69 El Camino without disc brakes. Wider drop center than normal DE 14X6 B-4 3/8 71-72 Nova & Chevelle, 6 hole wheels YW 14X6 B-4 3/8 Exactly like XB, may have come on same cars YJ 14X7 B-4 3/8 69 Camaro/ Chevy II L72- ZL1, 70 Nova AV 14X7 70-72 Camaro, 71-72 Nova, 6 hole wheel XT 14X7 L72- ZL1 Non Rally Wheel YA 14X7 B-4 3/8 69 Chevelle SS Wheel AO 14X7 B-4 3/8 70 Camaro &69 Chevelle SS Wheel DB 15X5 67 Passenger Cars with disc brakes. DF 15X6 B-4 1/16 67-68 Camaro Z28 DC(BIG) 15X6 B-3 1/2 67 Corvette, No other stampings on rim DC 15X6 B-3 1/2 68-70 Passenger car, 67 Passenger car (early models) FI 15X6 B-3 1/2 68-70 Passenger car, 67 Passenger car (later models) Riveted instead of welded together YS 15X6 B-3 1/2 68-70 El Camino FW 15X7 B-4 1/4 71-up most any GM AG 15X7 B-3 3/4 68 Corvette (will take 15x8 Beauty rings) YH 15X7 B-4 1/4 L72- ZL1 Z28 Rally 69 narrow drop center AD 15X7 B-4 1/4 L72- ZL1 Z28 Rally 68 wide drop center AV 15X7 70, 71, 73 CAMARO Z28 5 spoke wheel AZ 15X8 B-4 69-82 Corvette This will tell you what the wheels were originally for. This list is not all inclusive by the way. Good luck... GUSTO |
I think that has to do with the bead design and shape.
Originally Posted by 65specialk
(Post 1575970261)
Dave |
Are they ralleys or steel wheels? 63-66 Corvette steel wheels are 15x5 1/2 (as were the optional 57-62 wheels). 67 ralleys were the only Corvette wheels ever used in the 15x6 size. 65-66 OEM wheels are "J", and the service replacement ones are "JK"s, I think.
(Post 1575970261)
Dave |
Originally Posted by gbvette62
(Post 1575972713)
Does anyone have a comprehensive list for regular steel wheels?
My 65 had 15x6 rims with the nubs by the valve stem when I got it...they have a code of FL I've tried to identify these here and on google and have come up empty. |
1 Attachment(s)
Originally Posted by champs65
(Post 1575978236)
Are you saying the rim pictured is correct for a 66 Corvette?? Dave
(Post 1575990957)
My wheels are stamped 15X5 1/2 JK 8 64 .
So these should be correct for my early 65?? Dave |
(Post 1575996216)
