Powder coated calipers and brackets
I ordered the red brackets and calipers from Mike at tps motorsports and could not be happier. The powder is smooth and the color is bright and they make a huge difference in the cars appearance. Thanks again !!
https://cimg4.ibsrv.net/gimg/www.cor...dadd46e0e4.jpg https://cimg8.ibsrv.net/gimg/www.cor...a0c161ccfa.jpg https://cimg9.ibsrv.net/gimg/www.cor...8e183cae18.jpg https://cimg1.ibsrv.net/gimg/www.cor...1ce87f674b.jpg |
Originally Posted by Jgb71
(Post 1590182675)
Good amount of calipers in stock and ready to ship....
C5 Red (2 Sets) C5 Yellow (1 Set) C5 & C6 Candy Blue (1 Set each) C6 Candy Red (1 Set) C6 Gold (1 Set) C5 & C6 Black (1 Set each) C5 Silver (1 Set) C6 (2 sets no done so can make ANY Color You want) |
Looking for some Powder coated calipers to make your Vette stand out? Here's what we have available to ship immediately. Other and custom colors available for a short wait. Upgraded rotors and stainless steel brake lines available at a great price also.
C5-Red (2 Sets) C5-Silver/ Grey (1 Set) C5-Candy Blue (1 Set) C6 (Base)-Red (3 Sets) C6 (Base)-Black (1 Set) C6 (Z51)-Candy Orange (1 set) |
How much are the calipers,pads,and rotors all together as a package ?????
Originally Posted by Xavierbank
(Post 1590561561)
http://www.tpsmotorsports.com/corvet...liper-set.html |
Git rid of those ugly stock calipers and get a set of TPS Motorsports Power Coated & Rebuilt Calipers!
-Lots of colors in stock and ready to ship immediately! https://cimg3.ibsrv.net/gimg/www.cor...f376f07f97.jpg http://www.tpsmotorsports.com/media/...img_0017_1.jpg http://www.tpsmotorsports.com/media/...img_0022_5.jpg http://www.tpsmotorsports.com/media/...d/sdc19307.jpg http://www.tpsmotorsports.com/media/...d/sdc19509.jpg http://www.tpsmotorsports.com/media/...5/c5white8.jpg |
Sunday Bump... need to get your calipers rebuilt? Why not get them powder coated at the same time.
:thumbs::thumbs::thumbs::thumbs: |
End of 2015 Special for all Powder Coated Caliper Purchase!
Buy any set of powder coated calipers and we will give you a set of Speed Bleeders for them FREE OF CHARGE! https://cimg0.ibsrv.net/gimg/www.cor...2b40439ea4.jpg The old manual way of bleeding your brakes Bleeding brakes used to be a difficult thing to do in the past. It generally required two people to bleed brakes. You had to have one person pump the brake pedal while you had the mechanic open and close the bleeder screw. You had to coordinate the openings and closings with the pumper. If you didn't coordinate the timing correctly you could end up with more air in the system than when you started. The new and improved way Introducing SPEED BLEEDER?, the patented bleeder screw with the built-in check valve. It is truly a one-person bleeder screw. Once installed, it becomes a permanent part of the brake system. When it is time to bleed your brakes, you loosen the Speed Bleeder 1/4 turn and pump your brake pedal. When the pedal is depressed the pressure generated opens the check valve letting air and brake fluid out of the end of the Speed Bleeder. When you release the pedal and it returns to the up position, the check valve closes and prevents any air from reentering the system through the Speed Bleeder. When bubble free fluid is evident you close the Speed Bleeder. In the closed position it works just like your stock bleeder screw and prevents any brake fluid from leaking out. It generally takes about 5 pumps to purge each caliper or wheel cylinder. That is all there is to bleeding your brakes. If at a later date you need to bleed your brakes, the patented thread sealing system makes it easy to open the bleeder screw to perform the bleeding operation. It is made of quality materials and it is economical. |
Get a set of Powder Coated Calipers from only $299 now! Special December Christmas Pricing! Bump for our best sale of the year! Everything is on sale! Click here to place your orders http://www.tpsmotorsports.com/black-...-corvette.html 0% Financing Available for up to 1 Year on ALL PURCHASES! https://cimg7.ibsrv.net/gimg/www.cor...c16eee64dd.jpg |
so ive been wanting to upgrade to c6 brakes how can we make this work out and it it a direct bolt on
Originally Posted by justbrad
(Post 1591071174)
Originally Posted by TPSMak
(Post 1591071207)
We do not allow C5 calipers to be exchanged for C6. If we send you a set of C6 calipers you will need to send back C6 Cores
(Post 1591072599)
i dont thinmk you under stood my question how much would it cost to upgrage to c6 brakes for my c5 i dont care if i have to eat the 400 core charge I really need better brakes on my car and wilwood are way too expensiveI need rotors pads calapersin blue and lines please
https://cimg0.ibsrv.net/gimg/www.cor...29400dc71c.jpg https://cimg4.ibsrv.net/gimg/www.cor...f83650f4e5.jpg |
Swap out those ugly stock calipers while your Vette is put away for winter with our Powder Coated & Rebuilt Calipers.. from only $339 shipped to your door.
I just reviewed this entire thread and didnt see any C6 Z06 calipers. Do you powder coat those too? I am in the process of upgrading to those brakes on my C5 and may want them powder coated.
Let me know. :cheers: |
Originally Posted by ITSQUIK
(Post 1591590020)
Let me know. :cheers: Click here to place your order and get on the waiting list. http://www.tpsmotorsports.com/corvet.../calipers.html https://cimg5.ibsrv.net/gimg/www.cor...d8f737e736.jpg https://cimg6.ibsrv.net/gimg/www.cor...c7d709f98d.jpg https://cimg7.ibsrv.net/gimg/www.cor...87228e1656.jpg https://cimg9.ibsrv.net/gimg/www.cor...8916dcc3bc.jpg https://cimg0.ibsrv.net/gimg/www.cor...0dc147302e.jpg https://cimg9.ibsrv.net/gimg/www.cor...84a9ce4c38.jpg https://cimg1.ibsrv.net/gimg/www.cor...3f8dd75de9.jpg |
Spring is just around the corner!
Git rid of those ugly stock calipers and get a set of TPS Motorsports Power Coated & Rebuilt Calipers! -Lots of colors in stock and ready to ship immediately! https://cimg3.ibsrv.net/gimg/www.cor...f376f07f97.jpg http://www.tpsmotorsports.com/media/...img_0017_1.jpg http://www.tpsmotorsports.com/media/...img_0022_5.jpg http://www.tpsmotorsports.com/media/...d/sdc19307.jpg http://www.tpsmotorsports.com/media/...d/sdc19509.jpg http://www.tpsmotorsports.com/media/...5/c5white8.jpg |
SPRING IS HERE! IT's RACING & SHOW SEASON!
https://cimg7.ibsrv.net/gimg/www.cor...c16eee64dd.jpg Get rid of the the UGLY stock calipers with a set of our Powder Coated and rebuilt calipers! Pick a color we stock OR any color that's available! https://cimg1.ibsrv.net/gimg/www.cor...357847cbc3.jpg https://cimg2.ibsrv.net/gimg/www.cor...251cca09ef.jpg https://cimg4.ibsrv.net/gimg/www.cor...cb3e825d78.jpg https://cimg5.ibsrv.net/gimg/www.cor...b48848e77d.jpg https://cimg7.ibsrv.net/gimg/www.cor...0a36781a9a.jpg https://cimg9.ibsrv.net/gimg/www.cor...25fbf533fc.jpg https://cimg1.ibsrv.net/gimg/www.cor...4988cae52e.jpg |
Lot's of calipers in stock and ready to ship! No waiting for many colors for C5, C6, and C6 Z51! If we have it in stock we'll ship it out to you within 48 hours of placing your order!
