Egr valve removed vacuum lines can I remove?
Hi,
Egr valve deleted,what associated plastic vacuum line/hoses can I remove.Its on an 89 there is a rubber block attached to one of the thermostat housing bolts.that has several lines attached. Pic's if possible.:cheers: the air pump was by passed previously. |
You can remove the 2 vacuum lines associated with the EGR, the line from vac source(my 86 is bottom of TB, drivers side) to EGR solenoid (mounted to thermostat), and solenoid to diaphragm.
Just be sure to plug the vac source. :) |
Originally Posted by joshwilson3
(Post 1575810491)
At least on 89, the vac source at the throttle body goes to the solenoid and also runs to the front of the car via a 3-way. I'd say he'd have to cut the vac line on the left at the solenoid and plug that.
Or cut off the 3-way and connect together the throttle body line and the line running up to the front of the car. I've had to use some soft vac line to connect two hard vac lines before. Though I think they sell straight soft vac connector ends for hard lines. The hard lines should be 5/32". Any pic's? Just don"t want to accidentally delete the wrong ones and find out I'm chasing a vacuum problem |
(Post 1575812927)
You could probably just run a new piece of 5/32" hard line from the throttle body to where ever that line goes to. You'd just have to get some end pieces. You might could pull the soft rubber ends pieces off the old line and put on the new. This way you could save the old vac line.
http://img195.imageshack.us/img195/5...uum20lines.gif |
Originally Posted by Qiken
(Post 1575813256)
Looks like I can remove the EGR Solonoid attached to the thermostat housing in total,from the pic?and just continue the Vac line that just runs up to theT/B?
You end up with From rear plenum ports a line to fuel pressure reg a line to one way valve for HVAC / cruise/ vac ball A line from port under TB to the purge system valves under LH head light I just replaced all the stock plastic lines with with rubber hose where needed |
What do you expect to gain by removing those items? Performance? Not. :D
(Post 1575808036)
http://i171.photobucket.com/albums/u.../VacuumMOD.gif |
Originally Posted by vetteoz
(Post 1575814084)
