Ls3 turbo cost and potential.
I've always loved corvettes but just could never buy one because of the old midlife crisis guy stigma, and because the interiors kinda crappy. I'm really starting to entertain the idea of buying one to turbo now though.
I see obviously the APS kit, which looks like a pretty good value from the FI world I come from. 625whp ish isn't going to be enough for me for long so I'm wondering if many people have taken their LS3s to 800-1000whp and what kit if any they used and approximate costs. How much does it cost to send an ls3 to a reputable machine shop for building? I'm no stranger to FI, but I know nothing about american cars. |
someone just posted a dyno of a bolt on SC kit onto their LS7...737whp. not too bad. the LS7 has higher comp. than the LS3, so i say with a tune thats on point and some good gas you can break 800whp on an LS3 no problem. how long it will last depends on driving style maintenance etc etc. but if you have the means to build the right twin turbo setup, go for it! or go big single!
Don't have the means to fabricate it from scratch unfortunately, just install stuff and make minor modifications if needed for more power. I could build an engine but would want to send it off to a machine shop anyway so at that point it's just easier to have them assemble.
In regards to the compression, the higher compression motor should make more power off the same boost unless it's horribly limited on octane. Really I'm just wondering of an idea of what it would take to see if I should really start researching. I come from BMWs were 500whp costs you 15k and 700whp is your first born. |
Originally Posted by BoosterClub
(Post 1575764201)
(Post 1575764201)
(Post 1575764201)
Turbo kits cost twice as much to buy and install. I would recommend one of the awesome supercharger deals out there which are $6500 installed and tuned. With the right kit, you can just upgrade the headunit when you get that built motor if you don't want to buy everything all at once. Either way, think about your budget and be prepared to double it. |
Originally Posted by Drewstein
(Post 1575764245)
Either way, think about your budget and be prepared to double it. It looks like there's a whole lot of companies out there making stuff for vettes. |
i was looking on s2ki the other day and someone posted a vid of a 1300hp S/C'ed Z06. let me find it. looked pretty damn fast.
here: http://www.youtube.com/watch?v=dI8jK...layer_embedded and about the compression thing, i was referring to making that power on higher octane pump gas, not strictly race fuel. if you're talking strictly race fuel then yes compression doesn't matter as much. |
(Post 1575764275)
Nah no one would touch the car but me mechanically. I know there's some vortech units out there that can make some serious power. Anyone stuck a big blower on a built ls3? I didn't really consider a supercharger as be able to make big power for some reason.
It looks like there's a whole lot of companies out there making stuff for vettes. I had a 800rwhp C5 with a D1 on it. Imagine that with a nicely done F1. |
(Post 1575763873)
I see obviously the APS kit, which looks like a pretty good value from the FI world I come from. 625whp ish isn't going to be enough for me for long so I'm wondering if many people have taken their LS3s to 800-1000whp and what kit if any they used and approximate costs. How much does it cost to send an ls3 to a reputable machine shop for building? I'm no stranger to FI, but I know nothing about american cars. The stock LS3 is good for close to 700WHP before it becomes unreliable. Forged internals will cost you abour $4K, and a supercharger kit capable of your 800-1000WHP goal will need to include a fuel system, 8 rib drive, headers, blower cam, valvetrain, etc... 800WHP can probably be had for about $15. I won't comment on 1000WHP because a LOT can go wrong there; you'd have to spend money on a billet block, driveline, etc... Its beyond what I've bothered to research. |
Originally Posted by PowerLabs
(Post 1575764381)
Turbos are not very common on Corvettes because they cost double what a good supercharger kit costs and are double the amount of work to get right. They always seem to have some quirk with heat, oil consumption, etc... You will find that most cars here run superchargers, and most of those are centrifugals. It is cheap, simple, and (by virtue of its simplicity) pretty reliable.
(Post 1575764381)
Originally Posted by SBCGENII
(Post 1575764630)
And you definitely dont need a billet block for 1000rwhp .
So I think what makes more sense, now that I've looked around some more, would be a YSI + a built block. I like the A&A bracket and intercooler out of the ones I've seen. I'm trying to figure out exactly what would need to be done for the build, obviously forged rods and pistons, what about the valves and heads? New exhaust valves probably? Ported heads? different heads all together? Just trying to get ideas on cost. Fuel system is obvious and I would just upgrade driveline parts as the break. |
You shouldn't give up on the turbos just yet. The APS Z06 system comes with a fuel system and will support over 1000+ rwhp on a built motor. There are plenty of examples on this forum. The 625 rwhp you referenced was only 6 psi of boost on a stock LS7 motor.
Put forged pistons in your LS3 and turn the boost up ... you'll get to 800 rwhp and have plenty left if you want to build the motor later. That will cost you $15-20k depending on where you purchase the APS kit. Yes, turbos will take more time to install but once completed, they are virtually trouble free. That is well worth the extra couple of days it takes for the install IMHO.:cheers: |
(Post 1575764275)
It looks like there's a whole lot of companies out there making stuff for vettes. http://www.youtube.com/watch?v=EUeTlBF62Cw |
(Post 1575799548)
^%&$ I was about to say if I really need a billet block for 1Kwhp then I wouldn;t even bother, If we can get 1k out of a little 3.2 liter you guys better be able to get 1k out of a 6.2.
It is not a good argument though. First of all 1000HP from a small engine comes with a TON of caveats. Primarily: -Race fuel -Very poor off boost performance (low compression is mandatory) -Massive turbo lag (big turbo + small engine + low compression) -Poor reliability. More power from a smaller engine = more cylinder pressure. More cylinder pressure = more load on the connecting rods, bearings, rings, etc. barely m Also, and most importantly, the LS series engines were never designed or intended to see boost. They do fine with some boost, but they won't take NEARLY as much boost as an engine that was designed, developed tested and intented to see boost continuously, under warranty. You'll never get an LS3 to live at the same boost levels you can get a 2JZ / 4G63/ EJ257 / insert random turbo engine here. That is a simple fact of life. Of course, one of those 2 - 3L engines at 20PSI is still barely making what a heads/cam LS3 makes on pump, but stilll... Want a massive boost LS engine? Get one that was meant to see boost. The LS9 will do 1000+ WHP all day long, as will a C5R block, as will any LSX block with the right internals. You can make over 800WHP on a forged internals stock engine but it will get iffy much past that. Its been done, but as one of the forum tuners put it before: There is a big difference between what "can work" and what is reliable. If you want a 1000HP car, be prepared to pay a lot for it. You can pay a lot now, or you can pay a lot over the next several months as things take turns breaking between your engine and driveline. Been there, done that, don't recommend it :(
(Post 1575799548)
I'm trying to figure out exactly what would need to be done for the build, obviously forged rods and pistons, what about the valves and heads? New exhaust valves probably? Ported heads? different heads all together? Just trying to get ideas on cost. Just my 2 cents worth though; the BEST advice anyone can give you when it comes to these high power / big budget builds is to find the best shop in your area, talk to them, and agree on what you want, and how it is to be accomplished. My other 2 cents worth is to think about what you want all this HP for, and, if you've never experienced it, try to get a ride or drive a car with a lot of power... A lot of people get enamored by the idea of, say, having a 1000HP street car, but then find out that, in the real world, it is a huge PITA requiring constant maintenance and not really being that fast unless you are willing to run full on race compound tires and baby the throttle untill you are going over 100 miles an hour to get traction. Again, to offer some of my personal perspective; the jump from 600RWHP to 700RWHP for me came with a forged engine and methanol injection: I have to keep worrying about the methanol tank being full and keep having to find methanol and refill it, which is a PITA on long drives. I run full on R-Compound tires and can light them up at freeway speeds. Most of the time the car is not appreciably faster before about 70MPH despite the extra 100RWHP since it is traction limited to that point. The R-comps are expensive, have to be special ordered, last 7500 miles, have little grip when cold, and are BEYOND dangerous in the rain after they get down to their wear bars. I love having 700RWHP and I could even, at times, use more (BIG catch here; this is ONLY true on warm days, when the tires are warm, the road is dry and clean, and I have the space to really hammer on it and get the car going feloniously fast) since I love the high speed stuff (190+ MPH runs), but how many people here do that? For your average owner all the extra power means is less traction, more tire bills and that pesky meth kit issue... There is an ideal power number for everyone, and more is not always better... Even for me, and I absolutely LOVE horsepower and speed, for more than half of the year it is either too cold or too wet for me to do anything with this power other than just light the tires up and put the car sideways. Even on the drag strip it is hard to hook up; my Nittos spin 1st and 2nd and net 60' times in the 1.9 - 2.1 second range.
(Post 1575799548)
(Post 1575808616)
That is the quintessential ricer argument, right up there with the "HP/L" claims and how that somehow is supposed to mean something
It is not a good argument though. First of all 1000HP from a small engine comes with a TON of caveats. Primarily: -Race fuel -Very poor off boost performance (low compression is mandatory) -Massive turbo lag (big turbo + small engine + low compression) -Poor reliability. More power from a smaller engine = more cylinder pressure. More cylinder pressure = more load on the connecting rods, bearings, rings, etc. Also, the engine I'm talking about has great off boost performance and fully spools by 4k on pump gas. :cheers:
(Post 1575808616)
I also run methanol and have to fill my tank, I don;t find it to be a big deal, tire costs are not either, I live in florida so I don't worry about the cold, I am not an "average" owner who see the expense and lack of low speed traction as an issue. I find 800whp boring now. Also, work is free for me, I do it myself and have the spare time that it doesn't bother me plus I enjoy it. I'm actually really excited to work on an american engine since it's so much different then the OHC engines I normally work on. Back to talking about building stuff though. Youre stating a lot of stuff needing to be replaced, beyond the obvious and what I would expect. I would expect the block to be able to handle 1000hp, I expect to have to build the bottom end, have to port the heads or different castings and get new valves and springs. Obviously expected studs, but you're saying a lot of other stuff that I wouldn't have expected like the heads warping. You're also talking about "carving something out to be something it isn't but there is nothing you can just buy besides a Veyron that is designed to make 1khp off the shelf, this is what we do, start with a good base and modify it to make it better. To me it doesn't make sense to pay 3x as much for an ls9 and then go and replace all the parts you just paid triple for. or at the very least spend the same amount and have a WAY stronger set of materials. You said the ls9 can handle 1khp all day, but it's my understanding that they definitely have the same casting and possibly very similar finished blocks if not identical. Also the GS ls3 blocks have the ls9s forged cranks in them as well. I did see the lsx block, and it's something I would definitely consider, for a little extra why not get something bulletproof, I'll take cast iron over aluminum any day. |
I'm really interested in where this build is going........I'm tuned in for sure !!!
:lurk: My 0.02 ......an engine is not an engine........an early 90s 5.0 block from Ford could not structurally make 1/2 that of a 3.0 Toyota 2JZ.......please come here to use your past experiences from other platforms as a guideline but the engineering (geometry and materials) are completely different. You have LS3 heads, ask LG what they think of "duty cycles" on those castings. I think the general greater point missed in almost ALL FI threads is the duty cycles of a build...........just about everything can make XXXX Hp, good luck on some of those builds however. Ask the big builders who flogs/races their cars the hardest and they'll tell you what survived the massive selection of factory/aftermarket parts, and if you are truly honest with yourself you'll get what you want/need.........all these "what do I need" builds are honestly that simple. :lurk: |
Really wish I could change the title of the thread now.
Oh I know there's differences between blocks and generalizations are not very appropriate, but at the same time can be somewhat accurate so long as both are done with modern technology and with performance in mind, which I would hope the ls3 is. The ls3 head castings are poor? Is there a history of them failing? Luckily new heads are fairly cheap. And by cheap I mean way cheaper then BMWs which is 4k for a bare bones block and 5k for a new bare head.... you can see now why I am so interested in getting into the vette.
Originally Posted by j4three
(Post 1575802728)
(Post 1575809725)
(Post 1575809725)
(Post 1575808616)
You can mod the block for 6 bolts per cylinder while it is getting built, and run aftermarket heads with 6 bolt mains, but you're still on a factory cast liner, so it would be iffy... Sleeving the block is the safest way to hitting 1000HP, but at that point you can just about afford a billet block, and that, in my opinion, is a better way of doing it instead of carving out the factory block to be something it is not...
(Post 1575810223)
(Post 1575809725)
When I really thought about it though, I want to stick with a factory ecu, I have had nightmares with standalones and semi standalone units. And to do a turbo right you really can't use a factory ecu. Turbos are nice on smaller engines because you get great torque, but you guys get huge torque to begin with.
(Post 1575809725)
Powerlabs, you are missing the points completely, why I want the kind of power I do is my business, though I already explained it, no need continue trying to talk me out of it, it's futile, trust me. Go after the 2000hp lambos, I think that's more my "holy **** how would you ever need that much HP" point.
(Post 1575810885)
The LS3 heads are some of the best heads out there for the money, but they are not intended to clamp down an engine making 1000HP
(Post 1575810885)
a better option is to get an aftermarket head with a thicker deck.
(Post 1575810885)
You can probably get a stock engine block with forged internals to make 1000HP a couple of times. You'd be insane to expect that to last a long time.
As far as pushing using an ls9, just stop, I have no intention of using a stock engine, even if it's an ls9 especially one with such a premium as an ls9. I would much rather build an engine with components that can handle much more, balance it perfectly and so on. Looks like there wouldn't be much left but the block and maybe not even that, which is why I see what you;re saying with the ls9, but I'm very sure you could build a much stronger engine then an ls9 for cheaper from aftermarket parts.
(Post 1575810885)
Superchargers can make great torque too. And the factory ECU can handle most setups.
(Post 1575810885)
It is a boat anchor up front; 110 additional lbs. It will hurt handling. But it is stronger. I'd personally prefer an aluminum block to retain the handing, light weight and perfect 50/50 weight distribution which are some of the biggest sellings points of the car for me...
(Post 1575811322)
BTW lamborghinis are full time all wheel drive; they can harness big power a lot more effectively...
(Post 1575811322)
I don't think it's insane to expect, the displacement is huge. I don't expect stock internals to handle it, but I was expecting the block to, has anyone even seen a cylinder wall crack or a similar block failure
Here's another place worth investigatings: http://ecx.images-amazon.com/images/...SH20_OU01_.jpg http://ecx.images-amazon.com/images/...500_AA300_.jpg
(Post 1575811322)
Also, you can't even buy an LS9 block from GM. I was using it as an example of an LS engine meant for boost, capable of handling 1000 HP, vs taking an N/A motor and trying to push it to that power level.
(Post 1575811322)
A concern for sure but I intend to corner balance the car after completion.
You take the weight and deal with it. Its fine on a straight line car; it is still 200 pounds lighter than a Gen IV Supra for example. My point here is that for an extra >2K you can get an RHS race block that will be almost as strong, and keep the factory weight. |
1. I don't have a supra, if you read, I do bmws
2. I know I need to do research WTH do you think I made this thread for, I don't claim to know much of anything about LS engines but if you say something that goes against standard logic I'm not just going to believe you if you don't back it up with something. 3. You are pushing the ls9, read your own posts. Regardless there are tons of none meant for boost blocks that make 1khp reliably, and from less displacement, your generalization that if they aren't made for boost they wont take it is poor. 3. No I don't think the ls7 would be a good block, I know it doesn't have meat around the cylinders, from what I have seen the ls3 does though. 4. I never said minimal work, I expected a full engine build. 5. Corner balancing isn't only achieved by height adjustment. Relocation or ballast are quite effective. 6. if you've been down the path then why not share your actual experience, drop all this other ****, condescending/argumentative tone, judgment. All I am asking about is what is going to be necessary to put the power out, I don't need to hear your opinions on how a 1000hp car is dumb. If you want to help, help me find the examples of ls3 blocks that have failed, recommend some head castings that would hold up and flow well, things like this. If you don't want to help and just want to bicker then just don't help, I'm tired of bickering with you. |
