Which AC Delco Oil Filter?
Which AC Delco oil filter should I use on my 2006 LS2 6liter engine? I have seen conflicting recommendations between PF44 and PF48. I don't have the car and manual with me, but I want to pick up the oil and filter on the way home.
Thanks. Colin |
Purolator PureOne = 99.9% one pass efficiency :thumbs:
AC Delco
Originally Posted by ///DarkSide\\\
(Post 1575668905)
Purolator PureOne = 99% one pass efficiency :thumbs:
pf46, or pf46e (chances are you will only find the latter)
same as my 05, but I checked just to be sure on the Delco site :thumbs: |
Originally Posted by SEVINN
(Post 1575669153)
same as my 05, but I checked just to be sure on the Delco site :thumbs: Thanks for the reply. |
Originally Posted by BevoZ06
(Post 1575669268)
That's what I thought, and that's what I use on my two C5s. Gene Culley's GM Parts House Web site says PF44 for the 2006 LS2. That's part of my confusion.
(Post 1575669268)
PF46 superseded the PF44. Either one will work. Or you can use the UPF44 premium filter
Thanks for the replies. I picked up three PF46E filters.
Colin |
Originally Posted by JoesC5
(Post 1575671249)
Originally Posted by GOLD72
(Post 1575675165)
:iagree: The 2006 LS2 was the last year that used the 44/46 series filters. The 2007 LS2 and 2008 LS3 uses the 48 series. The 48 series uses a different mounting thread pitch so don't even try to use a 48 series on a 2005/2006 LS2!!!!!!
Colin |
I use the UPF44 on my 06 and get them from Gene at GMPartsHouse,
(Post 1575669268)
Originally Posted by Bandit1
(Post 1575680684)
(Post 1575679427)
Thank you, Gold72. I got the oil and filters changed this morning on two of my Vettes. The third one is not quite due, so I will hold on to the other PF46E. Thanks especially for the warning on the different thread pitch.
Colin Some more background info: The PF44 was replaced by the PF46 six or seven years ago (with the exception of the premium UPF44). The only difference is that the PF46 got improved internal media. I have no idea why GM/AC Delco decided to change the model designation to PF46. Why not keep it as PF44? The 44 and 46 series are dimensionally interchangeable. :cheers: |
Originally Posted by Gene Culley
(Post 1575684198)
Actually, I list the UPF44, which is the UltraGuard filter that filters further down in microns, etc. There is no UP (UltraGuard) version of the PF46, which is why I recommend the UPF44. ;)
Colin |
I'd use a Wix! Ever since I found a A/C Delco filter that was made by Super tech. Or the same company as this A/C was the exact same internally as the Walmart Super tech. I'll use a Wix!
That's what I've been using on my 2006 since I bouught the car.
(Post 1575684198)
(Post 1575668779)
Thanks. Colin |
Originally Posted by danl72
(Post 1575694315)
PF48 is for the LS3.
