install engine with or without transmission?
I have my engine and trans out and was wondering if it might be easier to:
install the trans then the engine and bellhousing. install the trans and bellhousing then the engine install everything at once. I will be using a shop crane that will only reach over from the side. The front wheel need to be off and the car on jack stands, so the car cannot be rolled forward. Car is a 65 |
shove the trans all the way back in the tunnel
install the mill complete with bellhousing onto the front mounts lower the crane slightly bolt up the trans... install rear trans frame mount lower assy......jmo....good luck....:cheers: |
I also use a shop crane to install the engine/trans. and I have found that it is easier, for me anyway, to bolt everything together and then install it in the car. I use a hydraulic floor jack to assist guiding the transmission into place while lowering the engine. If you decide to use this method remember to plug the end of the transmission or your transmission grease will be on the garage floor instead of in the transmission. I use the front yoke from the drive shaft to plug the transmission. Good luck!
Me doing it, I'd put the transmission in place, bolted to the rear mount and bellhousing installed. Prop the transmission up to "in car" position, hold your mouth just right and the engine will slide right on the transmission.
If you do it this way, it works a little slicker if you leave the engine mounts off the engine so they don't hang up on the frame. My opinion, this is the safest way as it's very easy to smash or damage some expensive underhood part with the whole assembly being decked at once. You can drop the engine and never touch anything except the transmission and the frame. |
Originally Posted by GRTaylor
(Post 1575644758)
(Post 1575644758)
(Post 1575644758)
http://ww2.pooperscooper.net/vette_s...r_2008_025.jpg |
