Automatic vs Manual Trans
I have a 2010 Grand Sport with the A6/paddle shifters. I read somewhere that the manual cars have a transaxle but the automatic trans cars do not. That is, the automatic trans is bolted to the rear of the engine in Grand Sports. Anyone know?
The transmission is in the rear on both.
Originally Posted by clarkakirby
(Post 1575578669)
Crawl under the car and look |
Originally Posted by last901
(Post 1575578944)
Seems to me I read that somewhere too.
(Post 1575578669)
Tom |
Originally Posted by tim414
(Post 1575579288)
Hey man, I believe ALL C6's, whether base, GS, Z06 or ZR1 are REAR mounted trannies.
Frankly, I don't care if the damn transmission is in the glove compartment. I'm just agreeing with the OP that I seem to recall reading that the A6 was mounted behind the engine. Admittedly I may have misread something having to do with the manual transmission GS cars being fitted with the dry sump engine and the automatics not. Sorry if I insulted your intelligence... man. You may very well be right...man. Peace...man |
you are correct all trannies are in the rear.:iagree:
(Post 1575579847)
Hey man? Gee, that sort of salutation really gives you away as an authority...
Frankly, I don't care if the damn transmission is in the glove compartment. I'm just agreeing with the OP that I seem to recall reading that the A6 was mounted behind the engine. Admittedly I may have misread something having to do with the manual transmission GS cars being fitted with the dry sump engine and the automatics not. Sorry if I insulted your intelligence... man. You may very well be right...man. Peace...man :cheers: |
Originally Posted by ninjavette
(Post 1575580442)
http://planetsmilies.net/confused-smiley-17466.gif I think you're being a little over sensitive. I don't see where his comment can be interpreted as him talking down to anyone.....man ;)
:cheers: No offense intended, |
(Post 1575580462)
Yes, you're probably right. It's the bad thing about Email and forum responses.
No offense intended, Anyway, the drive train layout of all C6s is the same. Engine in front, trans and diff in rear. I'm not sure where this misinformation is coming from but it's also not the first I've heard/read it either. It seems someone out there is trying to confuse us. :crazy: |
All C5/C6 transmissions are mounted in the rear, whether automatic or manual. None can truely be called a transaxle, as even the manuals gear case is isolated from the diffential's and does not share the same lubricating oil.
Thats right
:cheers::cheers:
Originally Posted by Vette5.5
(Post 1575581109)
(Post 1575579847)
Frankly, I don't care if the damn transmission is in the glove compartment. I'm just agreeing with the OP that I seem to recall reading that the A6 was mounted behind the engine. Admittedly I may have misread something having to do with the manual transmission GS cars being fitted with the dry sump engine and the automatics not. Sorry if I insulted your intelligence... man. You may very well be right...man. Peace...man Is that how you wanted to hear it? :lol: |
(Post 1575581109)
A true "transaxle" has the final drive gears in the same case as the transmission gears, as in a front wheel drive car. In a C5 and C6, the final drive is a seperate unit. |
While we're on the subject, is the linkage from the shifter via cable?
Or some other method? Thanks! Mike |
Originally Posted by Cratchet
(Post 1575582724)
In Corvette Magazine, Issue #60, October 2010, an article beginning on page 42 wrongly states that automatic transmission equipped Grand Sports have "the gearbox mounted directly behind the engine instead of at the rear axle as it in on a manual tranmission-equipped car"....................
In their Issue #61, December 2010, on page 12 they straighten out their error. So perhaps that is what got some confusion started. Even a classy (my opinion) mag. like Corvette Magazine can and will make errors once in awhile. |
Originally Posted by See5see6
(Post 1575582857)
Perhaps so. Maybe the editor was having a bad day. Maybe he just goofed. The editor did apologize. My post was more in support of the original post by clarkakirby than it was to defend Corvette Magazine.
