10-PCM - No Comm
Started the car today and the car just stops and stalls in my driveway.
messages on the display - Reduce Engine Power Service Traction System Service Vehicle Soon Service ABS Ran the codes and got a code 10-PCM - No Comm Does this mean my computer is screwed up? I'm stuck with the car in my dirveway, car cranks and won't start. Any help is appreciated, Any Long Islanders around that can help? Thanks Bruce |
Thanks
This is my job today, I'll keep you posted
Originally Posted by 8VETTE7
(Post 1575572004)
If the BCM and PCM cannot communicate you are going no where.
Check the battery and battery cables to make certain cables are clean and tight and that the battery voltage with the Neg battery cable disconnected is greater than 12.5 volts. Also start checking grounds. Here is a link to a Bill Curlee thread about the grounds: http://forums.corvetteforum.com/c5-t...tion-long.html |
