PO530 code - removed A/C - what voltage is necessary?
I am getting a PO530 code b/c I removed the A/C and I think it is causing a CEL (that is the only code that shows up when I check PCM codes). I'd like to feed the wires the proper voltage to avoid the code - anyone know what it should be (someone please test!!)?
Thanks! |
Originally Posted by RX-Ben
(Post 1575348885)
Thanks! |
checking through the DIC.
Good to know. I need to pull the latest round, but that was the only thing that showed up previously so I thought I'd check in advance. |
