Rubbing / scraping noise from rear wheel(s) - best place to support?
My '69 is making a rubbing / scraping noise intermittantly from the rear wheel(s). I tried jacking it up to spin and check, but it just doesn't seem like a good idea to have the wheels hanging down like that.
Where is the best and safest place to support the back end so I can spin the wheels and not have them and the suspension just hanging there? Thanks! |
put the floor jack under the outer leaf spring to trailing arm bolt :thumbs:
Hammadown :flag: |
Maybe the rear end/posi?
Does the rubbing/scraping noise seem to be more prevalent when making a slow or accelerating turn? Sounds as you describe can sometimes be the posi telling you it would like some new lube.
check the inside of the tires specially if you got 255's on as the e-brake line may be rubbing the tire
Thanks for the suggestions. I only have one floor jack. Where would one put jack stands to get the back end off the ground so I could have it in neutral and spin the tires and not have the suspension just hanging?
It sounds more like actual rubbing, rather than something from the posi rear. But I don't know for sure yet. |
Vader vette
Originally Posted by Allen_396
(Post 1575314432)
Where is the best and safest place to support the back end so I can spin the wheels and not have them and the suspension just hanging there? Thanks! The clutches are grabbing I know its hard to belive that any fluid you add can make a noise quit but Ill buy your lunch if the clutches are grabbing and the rear end lube doesnt fix it. now wheel bearing thats another thing ( but it makes that noise at a different time) |
Could be the emergency brake pads that are located inside the rotor.
They act just like a drum brake to hold the car. The springs are notorious for breaking and allowing the shoe to ride on the inside e-brake surface. That could explain the rubbing sound. :yesnod: |
Originally Posted by Lon Wayne
(Post 1575321230)
When did you last change out the rear end fluid .Two bottles of posi additive & fill with chevy lube $9.99 on the additive and are you sitting down? and the fill two bottles $16.00ea. "ouch" time)
It did stop the noise I was hearing. The previous owner had no record of the rear end service so I have no idea how long it had gone. |
I changed out the rear end fluid a couple of years ago, and then promptly leaked it out over time due to a bad pinion seal.
It has a new seal and new fluid. Where would one put jack stands to get the back end off the ground so I could have it in neutral and spin the tires and not have the suspension just hanging? |
Vader Vette
(Post 1575323331)
I am curious about the answer also. I think Allen is getting at the rear wheels dangling is not the way to rotate rear wheels. They need to be up off the ground, and lifted to somewhat the normal driving height if that makes sense.
Originally Posted by tonak
(Post 1575331950)
I have one floor jack and a few little jack stands. It didn't seem safe to support it on that big bolt back there on each side. So, I was wondering where to support the back end so the suspension is like it was on the ground, but so I can spin the tire or take it off and find the source of the rubbing. |
see if your bump stop plates on the t-arms are bent down and catching the ujoints... i had that issue
(Post 1575337481)
Exactly! I don't want the suspension dangling down due to not knowing what sort of unnatural bind it might put on the U-joints when I try to spin the wheels.
