Removing 3M Clear Bra - please help!!
I'm having some bodywork done and for that and other reasons I have decided to take the clear bra off of my '06 coupe, and I'm having issues.
To give a little background - I've taken parts of my clear bra off in the past TWICE (once the front bumper and once the hood), both times I was able to get it off successfully with no real issues. Both times, I removed the bra and a small amount of adhesive was left behind. Per the clear bra installers advice, I used 3M adhesive remover to remove the small amount of remaining adhesive, and had no issues doing so. This time, I removed the clear bra off my hood and front bumper and I have a HUGE amount of adhesive left behind. I've been trying the 3M adhesive remover with very little luck. I called my detailer to come over and help me, and he isn't having any more success than I was. I am afraid I am going to destroy my paint if I continue :ack: I called the 3M clear bra installer to see if he has any advice or if this is covered by the clear bra warranty, and left a voicemail. In the meantime - any advice here? How can I get this adhesive off without destroying the paint? Please help http://i37.photobucket.com/albums/e5...6/DSC_0001.jpg http://i37.photobucket.com/albums/e5...6/DSC_0002.jpg http://i37.photobucket.com/albums/e5...6/DSC_0003.jpg |
[QUOTE=Lebowski;1575310664]
This time, I removed the clear bra off my hood and front bumper and I have a HUGE amount of adhesive left behind. I've been trying the 3M adhesive remover with very little luck. In the meantime - any advice here? How can I get this adhesive off without destroying the paint? Please help As a retired chemist I would tackle this job using a series of solvents that would be progressively more polar. Let me suggest start with a rag and just an oil such as 3 in one. One then moves on to a product called "Goo Gone." This is a petroleum product too. If your adhesive still doesn't move then the last thing I would try is Xylene (paint department of WalMart). The rag here you use has a part in this effort too. It should be perhaps a hand towel and not something like a T-shirt. It needs to have an aggressive surface. |
I had a similar situation with part of the remainder on my bumper. Soaking it with the 3M adhesive remover for about a half hour seemed to help, and I also used some WD-40 as well. The material has kind of de-laminated, the way I see it, so you have most of the outer layer off but the adhesive portion has remained. Allowing the remaining material to get hot from the sun may also help. At this point you'll probably be lucky to get it to come off in large pieces, so patience will be the key...
Originally Posted by trivette
(Post 1575311250)
Did you use the 3M Adhesive remover in the aerosol can? I've found it dries up pretty quickly, so how did you soak it for 30 minutes? Keep spraying continuously, or soak a rag in it and leave that on the car or what? Any risk prolonged exposure to the 3M Adhesive remover will damage the paint? |
Does anyone know the difference between the different 3M adhesive removers?
I called a local paint supply store and the girl who answered the phone suggested 3M adhesive remover for wood grain and stripe removal. Does anyone know if it's safe to use on our clear coats? Looks like it's this: http://www.amazon.com/3M-Automotive-...405591&sr=8-17 http://multimedia.3m.com/mws/mediawe...6EVs6E666666-- Otherwise there's a 3M adhesive remover (which I have, and used with limited success) and 3M "general purpose" adhesive remover: http://www.amazon.com/General-Purpos...405327&sr=8-14 |
Just one of the many reasons why I do not install 3M film. Their adhesive is too strong and is a pain to take off.
I use the 3M remover but it comes in a bottle. It is easier to soak the adhesive with. Good luck and sorry for the hassle. I have been there, done that numerous times before. |
Originally Posted by Texas_Venom
(Post 1575313379)
I use the 3M remover but it comes in a bottle. It is easier to soak the adhesive with. Good luck and sorry for the hassle. I have been there, done that numerous times before. I bought a bottle of it today, both the general purpose (in a bottle) and the wood and stripe type (in an aerosol). I also got some acryli-clean (recommended by my paint/body shop guy). We'll see. I'll give it some more effort tonight when I get home from work. |
Yes you can get it off it just takes a lot of effort. I try and use heat on the film before removing it and it helps minimize the adhesive left on the car. But once it is on there you just have to work on it. Allowing the adhesive remover to soak in for a while helps. I have also used Dawn dishwashing soap... just coat it on there and let it sit for a while.
Good luck with it tonight... |
WOW! :eek:
Not trying to be a smart guy or anything but doesn't it defeat the purpose of getting a clear bra, if what it leaves behind is adhesive all over the clear coat that destroys the paint? I was always skeptical about the end result if you ever had to remove it and from the looks of things, I am not sold on it. |
LBear, 3M uses a very agresive adhesive. Other films use adhesives that arent as strong. I have pulled VentureShield off of cars and not had a bit of adhesive left. I have also pulled Nano Fusion film off with the same results. This product has been out almost 20 years and people are using it more and more. Comparing all films together is like saying my Corvette broke down on me so I wont by a Honda. You cant put all films in the same category as each are different. Be skeptical all you want... and in the meantime enjoy the rock chips.
Here's the solution! The adhesive remover has to be active for 30 minutes or more. Put it on an cover it with plastic wrap (your wife will have some - this keeps it from drying out. After about 45 minutes, pull the plastic wrap off and it will come off. You can carefully use a soft plastic scraper or teflon spatula.
I did the whole wing of my airplane like this and it came out perfect - no scratches and the paint was beautiful. Joe:thumbs::thumbs: |
Great reply very informational.
[QUOTE=Curtis A. Franz;1575311197]
Originally Posted by Lebowski
(Post 1575310664)
Good luck please let us know how it goes
Originally Posted by LBear
(Post 1575318422)
WOW! :eek:
Not trying to be a smart guy or anything but doesn't it defeat the purpose of getting a clear bra, if what it leaves behind is adhesive all over the clear coat that destroys the paint? I was always skeptical about the end result if you ever had to remove it and from the looks of things, I am not sold on it. Clear bras do have their advantages - if you drive a lot of highway miles, it does protect from rock chips. But they also come with drawbacks, and this is one, as is the line that eventually gets filled with wax. Also, when the clear bra does get damaged it isn't exactly cheap to replace. To be fair, it isn't always this difficult to remove. I've removed part or all of my clear bra on two separate occasions in the past, neither time did it leave this much adhesive behind. I even wrote a brief tutorial on how to remove the clear bra here on Corvetteforum a few years ago (and yesterday when I was searching the forum, I came across my own writeup, lol). I think the reason I'm having so much trouble this time is the bra had been on for much longer (about 4 years for the hood section, which left behind the most adhesive). In the past, the bra came off in one piece without tearing. This time, the hood section kept breaking, I'm guessing after 4 years of sun exposure the resin must weaken. I didn't use a heat gun, but I did park the car in the hot FL sun for several hours before removing, which didn't seem to help at all. Strangely, I removed the bra from the two front quarterpanels last night, without the help of heat from the sun or a heat gun - one side came off in one piece and left NO adhesive behind, the other side left a fair amount of adhesive behind. Bottom line is, I don't think I'll ever put a clear bra on any of my cars ever again after this experience. What a massive PITA - I'd rather just pay my bodyshop to repaint the front bumper if the rock chips get that bad. |
Thanks for the help guys - last night I put about an hour and a half into it, using the 3M general purpose adhesive remover (I bought both an aerosol can and a can of liquid). I made a pretty good dent, but I have more work to do. I'll put about another 2 hours or so of work into it tonight, and hopefully that will be enough.
Thanks for the suggestions - the spatula sounds like a good idea. I was afraid to use any hard scrapers but I have a soft silicone spatula that could work well. I'll try the plastic wrap, too. |
I'd like to second the motion on WD-40. I've owned vettes for over 20 years and found it to be useful when many other items fail. Spray it on a small area and massage it into the adhesive with a a soft cloth. Flannel is good, but an old T-shirt will work.
Good Luck, |
Originally Posted by Ron one
(Post 1575319974)
Good Luck, |
(Post 1575320020)
It's safe on the paint?
:flag::seeya |
lol razor blade??
Originally Posted by robertaj
(Post 1575320631)
lol razor blade??
Thanks but no thanks |
