What intake manifold gasket do I need? LT-1 heads on 350
Hey guys, I already ordered up the wrong gaskets and wasted 40 bucks.
I have a 350 small block with 71-72 LT-1 75cc heads casting number is 3973487. Here is a picture http://sphotos.ak.fbcdn.net/hphotos-...0_996779_n.jpg I just got these gaskets in http://www.jegs.com/images/photos/300/375/375-1205.jpg http://www.summitracing.com/parts/FP...n/?prefilter=1 There is no center hole which I think is exhaust for EGR function if I wanted to use it. And its too tall, can't get valve covers on. and they do not fit even though they say they are for a small block chevy. Now I see in the text that it won't fit an LT-1 setup so I am having a hell of a time figuring out what I need. Help please! THANKS |
Originally Posted by arcticcatmatt
(Post 1575227260)
Since the LT1 engine has a 'reverse' flow cooling system, can that setup use a typical intake manifold for a carb versus the injection system the LT1 came with ???
71/72, LT1 heads pictured did not have reverse flow, fuel injection.
Originally Posted by mar
(Post 1575228995)
My 'bad' - I had my wife's '95 SS Impala on the brain. The engine is called 'LT1' and it features reverse flow cooling to run a little more advance with the computer.
Originally Posted by hdpete98
(Post 1575232728)
71-72 did not offer fuel injection or reverse flow cooling.
Thanks little mouse. I will check that out. It appears the center is not cut out though?
http://static.summitracing.com/globa...e/FPP-1256.jpg This is for a supercharged engine so I am told I need the metal center gaskets. I am confused what you others said. These heads were designed for fuel injection? What is reverse flow? I looked up the casting number 3973487 and the internet told me 71-72 LT-1 heads, thats all I know. This was a drag car I am converting to be more streetable. I took the dual carbs and NOS off.. it is keeping the blower and the new holley blower carb and hilborn scoope are going on as soon as this stupid intake is figured out :cheers: |
Coolant flow was reversed thru early-mid-90's 5.7L 'LT1' engine and 9C1 engine. The additional cooling facilitated more advance through the systems computer and the result was a fine running engine that would rev really fast. I believe the Corvette LT1 in that era had aluminum heads and/or aluminum block, but don;t quote me. The SS Impala and 9C1 was all iron. All this on 89 octane. You could 'tune' the engine to run even better by tricking it into using 93 octane, installing cooler t-stat, freer flowing air intake, headers + 2.5" exhaust, etc. It was a sleeper of a big car. We had two SS Impala's and one 9C1 - they are truly neat cars.:crazy:
(Post 1575234527)
Measured a the ports tonight with my dials. 1.19 x 2.10. The gaskets little mouse said I need are 1.23 x 1.99 according to the website. Sounds like he is correct. I am hesitant to order them because the center port square isn't knocked out in that picture.
Many of the intake gaskets have that small hole in the center exhaust crossover or come with a little 2 piece stainless plate to install and restrict the amount of exhaust that flows thru there. My usual thing is to get gaskets that are 100% blocked or cut a thin piece of stainless and put that in there. But I'm trying to keep all the heat I can out of the intake.
^ Gotcha. I may do the same, considering I don't drive in winter and this is a supercharged car I have enough heat to deal with.
Here is a picture of the gasket that came out of it. These fit no problem with those valve covers. So I need a set of these whatever they are. [IMG]http://i4.photobucket.com/albums/y13...e/100_3103.jpg[/IMG] |
Just ordered these http://www.summitracing.com/parts/FPP-1604/
They look like the Felpro gasket you'll get when you go to NAPA. (If you look very closely, you should see: "This Side Up" on on side of the gasket. Did yours not have the metal restrictor in the center cutout?
(Post 1575246381)
(Post 1575242186)
As TimAT wrote ... cut your own Xover block from thin shim stock ... you can add that to an OE replacement-grade intake gasket & go racing; No problem. Glue shim to heads w/ silicone ... then install gasket as usual. Do NOT use aluminum shim; Al Will burn thru sooner than later.
-add- above is commonly used in restricted circletrack motors where both OE iron heads 487 etc & EB performer 2101 intakes are mandated. Cheap replacement grade gasket w/ a homemade shim is fine ... I run some rtv around the coolant & aircharge ports too. |
